02 type S, dies when coming to idle
after driving for a while, the car dies when you come to a stop, you can then start it back up and take off, but it continues to die when u come to idle or stop nearly every time..
what should i check on this??
TIA.
TIA.
re- set the ecu and see if that helps.
pull the 15amp ecu fuse and the 7.5 back up, wait a few seconds then put them back. turn the car on and let it run for about 5+ min without touching the gas. turn it off then your good to go. this should be done when the engine is warmed to operating temp first.
Joey Mitchell
Mar 17, 2019 05:00 AM
