How much would it be to make a B16a a 1.8 or 2.0?
Old Sep 14, 2002 | 03:45 PM
h82lose's Avatar
Default How much would it be to make a B16a a 1.8 or 2.0?
I got into a discussion about the b16 vs. a b20 and someone mentioned you could make the b16 into a 1.8 or 2.0 liter. How is this possible? Any links avaible would be appreciated. Also has anyone done this?
Old Sep 14, 2002 | 08:06 PM
civic disobedience's Avatar
Default Re: How much would it be to make a B16a a 1.8 or 2.0? (h82lose)
dont have the exact address but check out Crower, they make a b16 stroker kit, good stuff but its a bit pricey I think between $2500. and $2900.
Old Sep 14, 2002 | 08:20 PM
sparq's Avatar
Default Re: How much would it be to make a B16a a 1.8 or 2.0? (civic disobedience)
cheaper to just pickup an LS/CRV block and strap a VTEC head to it
Old Sep 14, 2002 | 08:21 PM
EG6-SiR's Avatar
New User
How much? More than it's worth.. go with a b20...
Old Sep 14, 2002 | 08:42 PM
I pretty much came to the same conclusion (B20) Im looking for a B20 to redo the internals and sleeve it then put my B16 PR3 head on it!! its not going to be cheap, but deffinitely worth it
Old Sep 14, 2002 | 09:12 PM
HXMan's Avatar
Ummm...send you block to golden eagle, get it resleeved and bored to 85mm....should be right at 1.8 liters then, with no stroking.
Old Sep 14, 2002 | 09:23 PM
bryant's Avatar
Default Re: How much would it be to make a B16a a 1.8 or 2.0? (HXMan)
Toda also has a kit
Old Sep 15, 2002 | 04:40 AM
h82lose's Avatar
Default Re: How much would it be to make a B16a a 1.8 or 2.0? (CR-X)
So its cheaper then just to spend more money on a b18c then go through the trouble with the b16a. Does anyone have any numbers for a stroked b16a? I figured when I first found out about it would be great because you would have a 1.8 or 2.0 liter engine with torque and also have the b16a's great rod to stroke ratio.
Old Sep 15, 2002 | 10:07 AM
the thing is you would loose the rod and stroke ratio if you go with a stroker kit, the golden eagle resleeve sounds like a better plan
madmoto154
Dec 11, 2008 09:08 AM
bayron
Aug 19, 2008 01:56 PM
egreenmachine
Aug 3, 2006 01:55 AM
K20Z3CivicSiVTEC
Nov 3, 2005 10:28 AM
civic-si-2000
Apr 7, 2004 12:58 AM
