Check engine light!!
Old Jun 29, 2010 | 12:59 AM
Wiretaju's Avatar
Default Check engine light!!
awrite so i just recently swaped my car from and auto to a 5spd.
my check engine light wont go off. does anyone know why???
thanks
Old Jun 29, 2010 | 06:37 AM
Nooch's Avatar
Default Re: Check engine light!!
lol check for how many flashes it is (do the paper clip test if need be. if its obd0 you should be able to view the LED flashing on the ecu underneath your front passenger floor rug) obd0 doesnt have long/short flashes, just beeps. Count the beeps; find the list of obd0 ecu codes (google is your friend) and go from there if need be. reply back with how many flashes it is and we'll help you out.
Old Jun 29, 2010 | 07:13 AM
Duane_in_Japan's Avatar
Were there any wires going to the auto trans that do not go the manual that went to the ECU. Did you accidently cut a wire during the job or plug two plugs into the wrong slot because they still fit perfectly, but now they are backwards. Yes, get the code for us first.
Old Jun 29, 2010 | 09:21 AM
lunalink's Avatar
uuummm...what are the specs on the swap? no info given so no info returned
Old Jun 29, 2010 | 09:25 AM
88whitehatchidaho's Avatar
i will bet its a code 19 (lock up control) there is a couple of sites that will show you how to change your ecu from an auto to manual. it just messin with a resistor or two on the circuit board i belive. Then the CEL will go off if that is the code
Old Jun 29, 2010 | 10:05 AM
Nooch's Avatar
Well there's no use trying **** before he actually tells us the CEL code
ej2 coupe
Jun 11, 2008 11:59 AM
h22honda89
10
Aug 19, 2007 02:40 PM
hondaeg95
23
Jan 20, 2004 04:51 PM
crxtreme27
Jul 1, 2003 10:53 AM
H22ACiViC
Feb 13, 2002 07:05 PM
