97 civic coupe jdm gsr swap
CASH OR CLEAN TRADE.. moneys going toward are car for my little bro... i owe him a car..
ek sedans w/ swaps
ek hatches w/ clean swaps
integra 4 doors or 2 doors
3800 Obo need gone first with 3700 ill take now!! price back up main problem fixed.. txt it 2629944370
LOCATION RACINE.
CAR:
1997 civic ex
5 speed
clean title
no burning
no leaking
no grinds in trans
heat works
power sunroof
power windows - only con is pass lock and window don't work with driver side control panel (need to replace the pass panel and everything works..
clean interior
alpine radio installed/amp & stereo stuff install will not come with subs or amp..
MODS
96 jdm b18c
s80 LSD trans no grinds
intake with new filter
p72 jdm gsr ecu obd2a
Skunk2 gsr manifold/w hondata gasket
New grey mugen replica valve cover
full h&r coilovers
skunk2 lower control arms -gold
skunk2 front upper camber kit
(cleaner all black front end added primered front bumper no fogs no cut outs no broken tabs..
Nrg quick release W/ hub 2.0 kit with W/ momo steering wheel black with red suade.
Brand new d16y8 engine harness no cuts paid 225
2000 si tail lights
2000 si front and rear seats
2000 si climate control
2000 si cluster
2000 si side skirts*
Unknown Short shifter
4-1 knock off aftermarket headers brand new with 2.5in collector to 2.5 megan test pipe to 2.25 straight pipe sounds good..
10k HIDs
Replaced New Inner Tie Bars
Fresh oil change.
New stainless steel clutch line.
Stainless steel fuel line.
New Fuel Filter
BADS
1 Crack in windshield
2 Passenger electric dont work..
3 No a/c
4 No p/s
5 minor rust on front end hood n fenders bubbles.
6 need to plug o2 and crank angle sensor in have a new sensor
Txt me for more info..(2629944370)
I have extra parts such as
jdm gsr valve cover w/ spark plug cover 80
All black LS meshes with tires 240 for em. snow tires mixed up i think forgot size
skunk2 lower lcas gold
obd2 gsr dizzy
just got a koyo half size radiator thats gonna be put in it maybe
have a aem 25-200c fuel filter with o rings brand new in box siver 75 shipped
I also have other MISC parts i will post later..
if anything txt or pm on here 2629944370
ek sedans w/ swaps
LOCATION RACINE.
CAR:
1997 civic ex
5 speed
clean title
no burning
no leaking
no grinds in trans
heat works
power sunroof
clean interior
MODS
96 jdm b18c
full h&r coilovers
2000 si tail lights
2000 si cluster
10k HIDs
Fresh oil change.
New Fuel Filter
BADS
3 No a/c
4 No p/s
obd2 gsr dizzy
what!!!!!!more then likely he is using the stock ex engine harness so im guessing he pluged it right up and if u look he is using a jdm ecu that plugs right in!!! y would he have a problem wiring up vtec it all plug and play
i have a stock ek hatch i posted on here..let me know,
http://hondamarketplace.com/showthread.php?t=2802498
Bump for a nice car!
Well my vtec kicks only when speedo/vss working so it needs a new one.. As for u noah txt me foo I didn't see that post but yah this axles are brand new.. U fix this car for me ill give u em for free.. I paid 200 for em. Just rxt me instead if my sister lmao 2629944370
Up top grabbed a new vvs for it today putting in tomorrow.
Fixed throttle cable/ replace tb with b16 tb.
Cleaned up the wiring a bit.
UP TOP
UP TOP
