97 Accord LX starts but then doesn't start
Old Jun 28, 2010 | 02:42 PM
b72649's Avatar
Default 97 Accord LX starts but then doesn't start
One day I parked my car (no problem up to this point) and then it didn't start anymore. The electrics came on but it didn't turn over or anything. (BTW it has a fourth tank of gas) I jumped the car but it still wouldn't start, so a few days later I took my battery in and had it tested, thinking it was probably bad (It is about four years old). It tested at 98% charge however, so I took it home and cleaned the connections and put it in and tried my car. It started! But only once, and it was slow to start - there was a scraping sound as it turned over, like iron wool scraping across metal. I thought, I bet it's the starter! So a week later I took that out and had it tested and it's working perfectly fine as well. So a couple days later I put it back in and tried starting the car, and it started up perfectly! I got in and drove it around a couple of miles and everything was fine. Then I brought it home and turned it off, waited a few seconds and started it up again, and it started like it had before, slowly with a scraping sound. I let it run for a few minutes, turned the car off and attempted to start it again, but it was dead again - the electrics came on but it didn't turn over.
Any ideas?
Old Jun 28, 2010 | 03:21 PM
Peeonu25's Avatar
Default Re: 97 Accord LX starts but then doesn't start
could be a grounding issue... check the ground connections.
Old Jun 28, 2010 | 04:16 PM
b72649's Avatar
Thanks for the idea!
I'm pretty new to working on my own car and I'm not sure how to check the ground connections. I didn't see any mention in the FAQ and my searches returned little that was useful. Any advice?
p00fyy
Oct 22, 2016 07:14 AM
yaga
Mar 27, 2007 09:07 AM
cornbread
Oct 24, 2005 09:59 AM
tjohnson329
Aug 14, 2004 12:02 PM
LordoftheAccord
May 23, 2003 06:11 PM
