torque spec for civic single cam oil pan?
Old Jun 28, 2010 | 12:03 PM
mengo911's Avatar
Default torque spec for civic single cam oil pan?
i want to know the torque spec for a single cam oil pan bolt????
Old Jun 28, 2010 | 03:04 PM
mengo911's Avatar
Default Re: torque spec for civic single cam oil pan?
anybody know?????
Old Jun 28, 2010 | 03:09 PM
Jdmglenn's Avatar
i like its like 10ft lbs per bolt right?
Old Jun 28, 2010 | 03:10 PM
Jdmglenn's Avatar
correction 8 ft lbs. dont over tighten
Old Jun 28, 2010 | 04:56 PM
mortificationrock's Avatar
**** my Haynes manual says- Oil Pan-to-engine bolts-120in-lbs.
^^WTF?
Old Jun 28, 2010 | 05:20 PM
95EG2's Avatar
^^WTF?
WHAT???? THAT CRAZY DONT DO THAT IT 8 OR 9 FT/LBS
Old Jun 28, 2010 | 05:23 PM
95EG2's Avatar
NVM on my last post i though u wrote 120 ft/lbs...LOL... hayne manual is right 120 in/lbs is converted to 10 ft/lbs
Old Jun 28, 2010 | 05:32 PM
^^yup...i just noticed that too..LoL. So yeah its 10lbs
Old Jun 28, 2010 | 05:36 PM
Former User's Avatar
8.7 ft-lb
The bolts must be tightened in at least three passes and in the correct sequence.
Old Jun 28, 2010 | 05:40 PM
Well i got mine from a haynes manual. So unless it says 8.7ft-lb in a HONDA manual then i go by the book.
Old Jun 28, 2010 | 05:48 PM
My torque number was taken from the Honda Civic service manual.
Old Jun 28, 2010 | 06:00 PM
Ok..what ever works i guess.
Old Jun 28, 2010 | 06:39 PM
10 ft-lbs may be fine, not sure. I just wanted to post the number from the service manual and to mention that tightening the bolts in the correct sequence in several passes is critical.
Old May 23, 2014 | 10:33 AM
Gvonbargen's Avatar
Does anyone know the sequence?? Or have a link to the sequence? Need to finish oil pan gasket repair
Old May 23, 2014 | 12:25 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
92-95 Oil Pan D15B7, D15B8, D15Z1 and D16Z6:
Name:  92-95 oil pan.JPG
96-00 Oil Pan D16Y5, D16Y8, B16A2 and D16Y7 all use this method for torque:
What differs between the D16Y5/D16Y8 vs D16Y7/B16A2 is how much and where you put the gasket maker.
Old May 24, 2014 | 12:15 AM
driguy's Avatar
Protip: If the gasket protrudes out from in between the bottom of the oil pan and the block, the pan is on too tight.
I torqued mine down to 8.7 and it bent the pan, gasket pooched out, etc. I did this with 2 different pans, then on the 3rd one I tightened up the bolts enough so the gasket was not visible. Haven't had a drop leak since.
This is on a D15b7 so I can't comment on any other engine, this is simply my experience.
Old May 24, 2014 | 09:22 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I believe you need a new torque wrench or get yours calibrated, 8.7 ft-lbs is very little torque and would not bend the steel oil pan of the D15B7.
I did mine to 10 ft-lbs with an extension and it's been a champ since. (Extensions reduce torque).
If you were bending your pan, then it was waaaay higher than 9 ft-lbs.
Old May 24, 2014 | 10:12 PM
driguy's Avatar
I used a Harbor Freight 1/4" torque wrench with an extension. It's probable that I got one that wasn't good to begin with. I never had a problem with any of their other size torque wrenches but I believe I got a dud if that's the case.
Old May 25, 2014 | 05:39 AM
NotARaCist's Avatar
I never narc'd on nobody!
You used a precision tool from Harbor Freight. That's your problem.
Old May 25, 2014 | 06:29 AM
Could also be user error.
Old May 26, 2014 | 02:35 AM
driguy's Avatar
I'm going to agree with you on this one. That particular torque wrench (and the other ones they sell, why mince words) has various issues. Most of them stemming from the fact that HF tools are, by and large, pieces of ****.
Old May 26, 2014 | 02:57 AM
grumblemarc's Avatar
The Grumpiest
This is most likely your problem.
I bough a T-wrench from Autozone a while back and now that summer's here and I want to build my spare block, I'm scared to use it. Just going to get a Snap-on for piece of mind.
Old May 27, 2014 | 06:25 PM
NotARaCist's Avatar
FWIW, I absolutely love using my step-brother's Snap-On torque wrench. It's a clicker type, and I'm fairly sure that it's touched every nut and bolt on my engine at least once.
Old May 27, 2014 | 10:16 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Even Snap-On's should be calibrated quarterly or monthly in a shop setting depending on business.
Home use, probably 6 months to a year is a more typical wrench maintenance schedule.
Old Apr 15, 2019 | 08:44 PM
elshakankiry1's Avatar
i think 9 lbs
DCtito
Jun 9, 2006 05:22 AM
9 CRX si 1
May 20, 2006 11:50 AM
3s0n3
Feb 12, 2006 08:22 AM
siis2fast
Jun 30, 2005 02:31 AM
prjctCIVIC
Sep 1, 2001 09:53 PM
