a6, y8, z6, or another block?
91 ex with a6/y8 mini me swap.
My a6 block has over 300k on it, instead of changing pistons/rings, i decided to change over the entire block.
Just not sure which one to use. I've heard pros/cons regarding all the block i've listed to be used in a mini me.
I need some more thoughts on these block matched up with my y8. I know the y8 block would make sense, but i've heard that the z6 is a better block.
Im confused.
EDIT: this is NOT an "opinion" thread, i need to know which is a better block to be mated with a y8, or a mini me swap in general.
Im confused.
I've "heard" that the A6 has a slight advantage with respect to it's rotating assembly being the strongest but I'd have no way to prove that (or disprove that for that matter). In any case, since all the blocks you've listed are of the same displacement I'd personally say it doesn't matter which block you use because the blocks are mechanically the same. As long as it's straight and within spec, you'll be good to go.
Isn't there something about y8 oil pumps needing porting or shimming or something to perform as needed for some high performace builds? I would say the a6 if you can find one.
I know that an oil jet has to be removed from the a6 block in order for the vtec to work...i've never really looked into exactly what that means.
The oil jets are on all engines (at least D/B/F/H...couldn't comment on K as I've never gone through one of those yet). The difference in location is the VTEC motors have them in the head, non VTEC motors have them in the block. Think about it and you'll understand why you need to remove it when doing a VTEC conversion.
I'll have my motor pulled sometime in the next couple of weeks, so i could check this stuff out.
it's right at the top of the block when you take off the head towards the intake manifold side. It's dead center. You can pull it out with a pair of needle nose pliers.
a6 has a steel girddle as the rest dont. the a6 and z6 both have 2 oil ports for the crank as the y7 and 78's only have one making them more prone to rod bearing failure
-I am running all obd0, even with an obd2 head. Can i re-use all of my obd0 a6 block sensors when i install the z6 block? or do i have to use the z6/obd1 sensors and convert my harness?
-Do i have to do anything to my y8 head when i install the z6 block? as far as the oil ports go?
Oh, I plan on getting an obd1 p28 with an obd1 ecu at some point.
Alright, well cool. Now for a couple other questions:
if you are doing a z6 block you would not have to do anything with the oil ports because they are already removed from the factory.
