car died on the way home.....
Old Jun 28, 2010 | 04:04 AM
Elitesky's Avatar
Default car died on the way home.....
I just finished up a d16z6 swap in my 91 honda crx si.. took me forever to find out why the car was not reving past 3500 rpms which came to be the ecu i bought from ennohohbee from here was sh**. So i put a ecu i had laying around which was a p13 not the correct ecu but it worked just reved alittle at idle... so i ran it all weekend on the was home last night the battery light came on and the car completely died... my friend brought jumper cables and still wouldnt start... i put the p28 back into it just to see if it would start and still nothing seems like no spark? would the p13 ecu cause the distributor to fail? i dont know were to start with this..
Old Jun 28, 2010 | 07:34 AM
Laserjock's Avatar
Default Re: car died on the way home.....
I have a 90EX ECU if you want to buy. I know it works because I have used it to diagnose 2 no starts on a 91 and a 90 Si
Also see this post for ideas:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/fuel-problem-2793941/
Old Jun 28, 2010 | 08:35 AM
chivid's Avatar
well when the car won't rev over 3-3500 rpm its usually the crank position sensor going out on the distributor. so i try a different distributor
Old Jun 28, 2010 | 10:09 AM
Elitesky's Avatar
well the 3500 rpm isnt the problem now... the 3500 was before i put the p13 ecu in it... the p13 ecu ran fine till i was going home last night and car shut off and battery light came on... but jump start wont start it so its not the alternator... so im thinking distributor..? no?
Old Jun 28, 2010 | 10:18 AM
Nooch's Avatar
ya try the distributor, i've had this problem before and it wouldn't jump and it turned out to be the rotor in the distributor cap. ~$7 fix.
Old Jun 28, 2010 | 12:03 PM
Elitesky's Avatar
imma check the local parts place and see what i can get for the distributor
and see if that fixes it... would that make the battery light come on, on the dash?
Old Jun 28, 2010 | 12:31 PM
lunalink's Avatar
^ your alternator is gone get a rebuilt one and that should solve it along with the dizzy
Old Jun 28, 2010 | 04:20 PM
FOMULA91's Avatar
Double check if your timing belt didn't snap... I went to go help my friends Civic that die while driving and I took a working distributor but it still had no spark.... Pop open the valve cover and I see no belt...
Old Jun 28, 2010 | 07:27 PM
Laserjock's Avatar
snip
snip
snip
Sorry didnt see the part about the d16z6. Are you using a d16z6 dizzy?
It's not the alternator see bold in quote. Yes, make sure the timing belt is turning. I took off my cover a long time ago and never run w/o it so it's always quick to see.
Open your dizzy cover and make sure the rotor screw did not fall off. Easy check - you dont even have to remove the dizzy. Pull the plug wires off and remove the 3 - 8mm bolts.
How are you checking for spark?
Old Jun 29, 2010 | 09:00 AM
Elitesky's Avatar
buying a distributor tonight.. timing belt does turn i also dont have cover on mine. and the rotor and cap look fine... have power going to distributor and no spark when i pluged in the fake spark plug to see if there is spark... so its gotta be distributor
Old Jun 29, 2010 | 11:31 AM
Laserjock's Avatar
I'd check the ignitor or ignition control module 1st
Ignitor should measure 18-25 Kilo Ohms depending on what type you have
ICM is more involved and I dont have access to manuals at this time
Both are in the distributor but could save you some $$$
Old Jun 29, 2010 | 12:39 PM
Elitesky's Avatar
are those sold seperatly then the distributor? or will be easier to just buy the whole distributor?
Old Jun 29, 2010 | 01:15 PM
lunalink's Avatar
ignitor from autozone is $70
a used working dizzy is $80
LOL. you decide
Old Jun 29, 2010 | 06:11 PM
chivid's Avatar
LOL. you decide
what he said....
Old Jun 29, 2010 | 07:03 PM
Laserjock's Avatar
ignitor from autozone is $75
a used (unknown?) working dizzy is $80
LOL. you decide
How long before that 5 -7 year old dizzy fail. Oh wait they're infallible
lol, you decide
Old Jun 30, 2010 | 05:15 AM
Elitesky's Avatar
bought a brand new distributor cap and rotor and the baby started right up drove it home and back to the shop.. new distributor was 125 so pretty cheap... i work at a dealer and my dad owns a shop so i get whole sale
Old Jun 30, 2010 | 03:56 PM
Laserjock's Avatar
coolski!
know anyone selling a cheap, busted @$$ D16Z6 distributor? <- is serious
Old Jun 30, 2010 | 04:02 PM
Laserjock's Avatar
coolski!
91crx93civic
Mar 22, 2010 06:34 AM
nuskoolty
Dec 9, 2006 07:38 PM
blu3g
Jul 19, 2006 05:33 PM
dasistheone
12
Aug 24, 2004 01:29 PM
lude97dude
Jul 23, 2003 11:54 PM
