Wiring Problem
Old Jun 27, 2010 | 08:24 AM
seanabekasis's Avatar
Icon2 Wiring Problem
I put d15b6(88 crx hf) into my honda civic si hb. Were tryin to make fuel efficient 4 seater. the only problem were having is the 4 wires on the evap system. green, red, blk/yellow,blk/yellow. Does anyone know where these 4 wires run to? im assuming they go to the ecu but not sure. Thanks.
Old Jun 27, 2010 | 10:34 AM
jlicrx's Avatar
Default Re: Wiring Problem
the 2 black/yellow wires are both power (one for EGR solenoid and one for purge solenoid) and connect together inside the harness and also connect to other black/yellow wires which ultimately end up at Fuse #14 in the under dash fuse box
the red wire is the signal for the EGR solenoid on the firewall and goes to ECU pin A10
the green wire is the signal for the purge cut-off solenoid on the firewall and goes to ECU pin A6
Old Jun 27, 2010 | 12:20 PM
thanks alot i appreciate it.
thrasher324
Dec 28, 2016 01:59 PM
tumbaumba
Engine Management and Tuning
Aug 16, 2016 03:34 AM
Sobe_Death
Apr 21, 2005 11:21 AM
Tex Blackwell
Nov 24, 2004 07:35 AM
