JDM H22A with bent connecting rod.. what else could be wrong
Old Jun 27, 2010 | 06:46 AM
93civproject's Avatar
Icon2 JDM H22A with bent connecting rod.. what else could be wrong
hey there i am new to this site it has given me some great info on threads i have read.but i need some help now..i have found a jdm h22a1 for what i would say would be a really good deal but the catch is it has a bent connecting rod.. i can replace the rods and pistons but i haven't really dealt with blown and damaged engines much so. im wondering what else could be wrong with it..would it be worth buying to rebuild?? any insight would be great ..thanks
Old Jun 27, 2010 | 07:16 AM
minilogoguy18's Avatar
Default Re: JDM H22A with bent connecting rod.. what else could be wrong
The cylinder liners are most likely damaged and FRM can only be honded so much and requires a specific honing procedure to do it correctly. H22a1 is USDM motor btw, H22a is JDM, if yours has a 1 or 4 at the end then someones misinforming you about the motor they're trying to sell.
Old Jun 27, 2010 | 12:12 PM
flyrod's Avatar
A bent rod is usually from sucking water through the engine. If the rod is not bent much that could be the only problem. If it's bent a lot it could have taken a notch out of the block which could have messed up the piston which could have dragged debris up and down the cylinder if the engine kept turning, the piston could have hit the crank and the oil jets, etc. If the rod broke there could be a lot of damage. Also look for rust/corrosion related to water in the engine, look for a bent crank, possibly a bent wrist pin or cracked piston also.
Old Jun 27, 2010 | 12:37 PM
cloviskilla's Avatar
i put 33 pounds off a 60-1 to a stock ls and bent a rod. i just replaced the rod. but if u run them long with a bent rod it will **** up the cylinder walls. and we all know about h22 cylinder walls
Old Jun 27, 2010 | 01:30 PM
nus_dogg's Avatar
Just inspect everything thoroughly when have it all layed out. Check the Cyl walls, pistons, head + valvetrains and what not. Good Luck.
Old Jan 19, 2018 | 11:54 PM
Ronnie Shedd's Avatar
can a single piston, rod,and bearing be swapped or just rod and bearing on a h22a4 with good results
Old Jan 20, 2018 | 05:51 AM
TimiK's Avatar
10 Year Member
Of course it can be done but the result might be.. Not that long lasting
All cylinders should be inspected while you're there and start tearing your engine apart - no point just do one
93civproject
Jun 28, 2010 07:04 PM
SiR Inspired ED7
Mar 17, 2010 03:26 PM
ExplicitSpeed360
Jul 16, 2006 12:05 PM
