Road To Redline Build
After being literally begged to post up a build thread, we decided to post up our build from stock to redline/autocross/road race ready.
Our subject a 1989 Honda Civic DX Hatch
Motor: Fully built b16a swap
B16A Motor Build
Honda B16A - Thermal Shield Intake Manifold Gasket
Honda B16/B17 - GEM Turbo Intake Manifold - Polished
Acura B16A Headstud & Mainstud Kit
Arias Honda/Acura B Series 3.189 / 81.00 1.185 7 11.1 278 part #3330210
Brian Crower Crankshaft - B16A Honda
Brian Crower B16A/B18C - 33mm Intake Valves
Brian Crower Valves B16A/B18C - 28mm Exhaust Valves
Eagle'' H beam rods
Honda/Acura B Series GEM Fuel Rail Black w/6AN
ACL Race Bearings
Honda/Acura Adjustable Cam Gear - Black Outer, Silver Center
Honda/Acura Civic/Integra B16/17/18 Block Guard
Main Girdle Kit
Oil Dipstick - Honda/Acura B-series engines - Black
Skunk2 DUAL VALVE SPRINGS (Tuner-Series)
Skunk2 Stage 2 Camshafts - Honda
Skunk2 Titanium Retainers - Honda/Acura
Honda/Acura B&H Series Cam Seal - Polished
Honda/Acura GEM Magnetic Oil Drain Plug
Port & Polish,angle job,honed, Gasket Matching, Any apprioate machine work to make power
Apexi WS2 Exhaust
Hasport Wiring Harness/Swap Harness
Rywire OBD1 Distributor
Rywire OBD0 to OBD1 ECU Conversion Harness
p28 chipped & basemapped ecu
Alternator
Gates Racing Alternator belt
Apexi V-AFC
02 Sensors
Bisimoto Header
Magnaflow Direct Fit High Flow Cat
GEM Oil Cap, Honda Acura - Polished
Skunk2 70mm Throttle Body - Honda/Acura
Rims & Tires:
1 set of Axxis OGSan 15x7 Gold w/ Machined Lip Wheels for street and Teamdynamics 1.2's for track
1 Set of 195/50R15 General Exclaim UHP tire from Tire Rack
Suspension/Drivetrain:
Hasport EFBLINK shift linkage
Hasport Entry Level B-swap Axles with high temp grease 88-91 civic EF SK7 intermediate shaft
Custom Roll Cage/Bar
PIC Performance select coilovers 10kg f/14kg r
function7 lca's
Skunk2 front & rear strut bar through GEM
Skunk2 Rear Camber Kit Through GEM
Skunk2 Camber Kits - Pro Series Camber Kit (Front) through GEM
Energy Suspension Full Bushing Kit with trailing arm bushings
ASR Subframe Brace and Rear Sway Bar
Cable Trans
Clutch: Yonaka 6-Puck Sprung Hub Performance Ceramic Clutch Set Stage 3 Clutch kit
8lb Flywheel
RC Engineering Saturated High Resistance Fuel Injectors 310 CC
Regulator
Inline Fuel Kit
Walbro 255LPH Fuel Pump
Mishimoto Performance Aluminum Radiator 1988-1991
Mishimoto Aluminum Fan Shroud Kit, 1988-1991
Mishimoto Silicone Radiator Hose Kit 1988-1991
Thermostat
Battery Post and Wiring Kit Remote Jumper Terminals
B&M Short Shifter
sparco pedals
Bumper Diffuser - 1 Piece Flat Black
Tow Hook Kit - Front and Rear - Polished
JDM Civic J's Racing Style Front Lip
Jdm EF9 Sir Bumper Filler
JDM side markers
VIS OEM CF Hood
Braking:
Fastbrakes Front 11" brake kit
Fastbrakes Rear 11" disc brake conversion
15/16 Civic Master Cylinder
Shipping
Integra prop valve
Interior:
JSR (JDMsh!t Racing) Type R Style Seats
RCI 5 point harness 5 point red
Circuit hero **** and shifter extender
Password:JDM Dry Carbon Fiber Fuel Pump Cover (EF 88-91 Civic / DA 90-93 Integra)
And more.
We picked the car up for $300 and sold the engine for $200.
Day: 1
B16A Motor Build
Eagle'' H beam rods
ACL Race Bearings
Main Girdle Kit
Apexi WS2 Exhaust
Alternator
Apexi V-AFC
02 Sensors
Bisimoto Header
Rims & Tires:
function7 lca's
Cable Trans
8lb Flywheel
Regulator
Inline Fuel Kit
Thermostat
B&M Short Shifter
sparco pedals
JDM side markers
VIS OEM CF Hood
Braking:
Shipping
Integra prop valve
Interior:
And more.
Day: 1
m3tech95
Audio / Security / Video
24
Jul 4, 2012 04:28 PM
