Searched FAQ's... Rear "eyeball" replacement bushings?
Old Jun 26, 2010 | 09:36 PM
Bond's Avatar
Default Searched FAQ's... Rear "eyeball" replacement bushings?
Ok so I already searched the FAQ's with no luck at all.
So here's where I'm at. I need some replacement bushings for the rear shocks. Being a type-r setup I figured here would be the best place to ask. I've searched aftermarket companies like ES and such with no luck. Nobody lists a rear lower shock bushing for the "eyeball" setup.
Anyone know if there are poly bushings made for this setup? And yes clearly I'm not looking for stock rubber ones otherwise I would just go to Acura.
Thanks guys!
Oh and I'm talking about the actual bushing that goes into the shocks eyeball hole. All aftermarket stuff list the bushing that get's installed into the lower control arm. Thats not what I need. Can it be used in the shock even though it's made for the arm?
itr1244
May 29, 2007 11:47 AM
beyond-redline
Suspension & Brakes
Feb 6, 2007 05:12 AM
madhatter07
Suspension & Brakes
Aug 9, 2005 10:55 AM
D.Lansing
Sep 15, 2002 09:58 AM
thesource
Oct 17, 2001 10:32 AM
