Blown shock???
Old Oct 17, 2001 | 10:24 AM
thesource's Avatar
New User
Default Blown shock???
Here are the symptoms:
- bad sqeeking from rear over any bump (especially small ones)
- rear driver side is lower than other rear
Is the shock blown? What else could it be?
My current setup is Tokico Blues w/ Sportlines and Prothane lower control arm bushings.
Thanks
Old Oct 17, 2001 | 10:32 AM
jonsteR's Avatar
Default Re: Blown shock??? (thesource)
I have almost everything that you mentioned you did except my springs are H&R sport (should lower the same amount). Anyway, my driver side is a tad lower than the passenger side and I have mad squeaking right now comming from the prothane bushings.
Check for leaks (shocks) and maybe lube the trailing arm bushing and see what happens.
This is on a G2 LS though
kasperxtcy
Suspension & Brakes
Mar 24, 2010 09:14 AM
dkrex001
Oct 3, 2009 11:06 AM
itr1244
May 29, 2007 11:47 AM
Slvr_CRX
Apr 24, 2004 04:22 PM
Pengo
Jan 20, 2003 06:41 AM
