Suspension & Brakes Theory, alignment, spring rates....
Why is my car leaning?
Old Jun 26, 2010 | 12:16 PM
SoCal EJ1's Avatar
Default Why is my car leaning?
Car is a 1995 civic 2dr.
Front shocks off a 1995 civic (not blown, R/L combo)
Rear shocks off a 91 SiR (ok condition, R/L combo)
Everything is installed correctly, torqued correctly, and everything that is for the right is on the right, and left on the left.
My friends and I are baffled at WHY my car is leaning SO much?
For what it's worth, before I pulled my oem suspension off 2 years ago, the car didn't lean (or at least I didn't notice), and it has never been in an accident (frame is 100% straight).
ANY help asap will be much appreciated.
Old Jun 27, 2010 | 11:37 AM
SoCal EJ1's Avatar
Default Re: Why is my car leaning?
bump. please help
Old Jun 27, 2010 | 12:51 PM
Jenkinsal2's Avatar
if you are right and have no accidents/damage/bent parts. Its possible that the spring is not correctly seated. still fairly unlikely but that looks unsafe as is...
Old Jun 27, 2010 | 02:35 PM
SoCal EJ1's Avatar
We jacked the car back up to check everything and everything appears to be seated correctly. I'm seriously baffled.
Could it be the preload in the bushings on the control arms?
Old Jun 27, 2010 | 03:29 PM
Jenkinsal2's Avatar
Thats still a bit of a long shot but I guess its possible? Can you try counting the coils on each spring?
Old Jun 27, 2010 | 08:44 PM
alphalanos's Avatar
Has to be something with shocks, springs, or bushings are seriously twisted. Maybe try swapping in some different shock and spring to see what happens
Old Jun 28, 2010 | 08:34 AM
Tyson's Avatar
normal.
Old Jun 28, 2010 | 09:47 AM
proshift's Avatar
This could be a long shot, but could if have something to do with the sway bar being loose on one end and tight on the other?
Old Jun 28, 2010 | 02:51 PM
SoCal EJ1's Avatar
i'll check all these out when i get a chance. it's not the bushings themselves (RTA has a spherical bearing, FLCA has sphericals in it right now. RLCA seems just fine).
Thanks for the help guys, i'll keep you posted.
Old Jun 28, 2010 | 06:40 PM
G-Weezy's Avatar
My car is leaning on the rear driver side. I replaced the shocks, springs, LCA bushing. Added ITR bar, Beaks reinforcement kit and Beaks lower bar, extended top hats. I'm still puzzled. Coming down to the RTA bushings next. Hopefully that helps. They look pretty shot.
Old Jun 28, 2010 | 06:54 PM
TunerN00b's Avatar
Originally Posted by Tyson
normal.
QFT.
The car leans, because the weight is not 50/50 left/right.
Old Jun 28, 2010 | 07:07 PM
michael-crxsi's Avatar
normal.
Please explain?
Old Jun 28, 2010 | 09:05 PM
alphalanos's Avatar
I dont know, that looks excessive. My car never has that much difference between sides regardless of the slope. This car one side is an inch the other is about 2-2.5 inches.
Old Jun 30, 2010 | 07:07 PM
98civdx's Avatar
Master Detailer
How the heck is that normal?
Old Jul 1, 2010 | 08:30 AM
SoCal EJ1's Avatar
it's not. i've been around hondas for 9 years now. If it were normal, I wouldn't be asking any questions lol
Old Jul 1, 2010 | 08:55 AM
Tyson's Avatar
https://honda-tech.com/forums/showth...ghlight=uneven
https://honda-tech.com/forums/showth...hlight=leaning
woo~ woooo~~
Old Jul 1, 2010 | 09:00 AM
alphalanos's Avatar
Yes they are uneven stock but unless they are off wildly or my car is just an exception, this is too much. My car is no more than 1/4" difference on each side. You can hardly even tell. Springs and shocks.
Old Jul 1, 2010 | 09:38 AM
1.5Slowmatic's Avatar
because motor>transmission in weight. Look at the higher side, what sits on that side?
Old Jul 1, 2010 | 11:34 AM
alphalanos's Avatar
Yeah but look at his pics. One side looks like it has lowering springs and the other almost looks stock. Maybe y7 motors/trans dont have this problem or something.
Old Jul 1, 2010 | 12:42 PM
98civdx's Avatar
Master Detailer
true, but dont you think thats quite excessive?
bruins767
Suspension & Brakes
Dec 1, 2014 12:58 PM
EF Sedan66
17
Sep 5, 2011 09:00 AM
SoCal EJ1
13
Jun 29, 2010 08:13 AM
nObOdy65
Suspension & Brakes
Dec 13, 2005 11:31 PM
LAOS
Suspension & Brakes
22
Sep 16, 2005 09:21 AM
