'92 Hatch B16A 98+ITR header (Flex Pipe or Bracket Options???)
Here's My EH3 (owned it since '96)
Here's the new header with the heat shield.....sleepy stealth lol
I have a slightly mod'd B16A (60mm mandrel exahaust, Intake, CTR cams/ITR springs, Adj Cam Gears). I still have the virgin P30 in it for now and Adj gears are at zero still (getting a socketed ECU and dyno/tune later this summer)
I decided to run an JDM 98+ ITR header and purchased a 2.5" Magnaflow Cat. I put the header on and as many of you know...the lower bracket does not fit the B16 motors. It has a bend in it (to go around the half shaft) so fab'ing it is a little out of my comfort zone. So I decided to investigate....came up with nothing except mis-info (B.S. that it fits B16 motors) or runing a flex pipe after the collector. So, I bought an expensive *** piece of stainless 2.5" Flex Tube dual layer ($60 flex section is about 3-4" long). The outside layer is stainless mesh and inner layer that has a coil running through it. Well I have this hissing sound when accelerating. I thought it was a leak but after taking it back to the muffler guy and finding no leaks....we found the sound comes from this stupid flex pipe.
Does anyone have an option for a bracket that isn't too hard to fab???
I can cut/weld just don't want to purchase the OEM bracket if I can't mod it to work.
Or a non hissing flex pipe option? Also heard cheap ones will swell up to a pee size I.D
Rok_Stok
Oct 30, 2009 12:36 PM
Team 4
16
Nov 28, 2007 09:19 PM
Rust
Mar 9, 2003 08:08 PM
DC2_R
10
Jun 30, 2002 09:37 PM
