Just turned my car on yesterday... with a problem...
Old Jun 26, 2010 | 08:58 AM
Einhander276's Avatar
Icon3 Just turned my car on yesterday... with a problem...
Well, I turned my car on for the first time since my father and I have been working on it. It turned over beautifully, but when we tried to put in gear it wouldn't. It would grind like were not even holding the clutch down, but we are! I tried to tighten the clutch cable to see if that'll work but no luck. And its weird cause I could only go to the reverse gear and it gronds. 1 2 3 4 5th gears wont even engage. But when the car is off, I can engage all the gears... when the car is on only reverse, and that gear grinds...
This is what weve done to the car.
New flywheel and pressure plate
New pilot baring
New passenger axle
new water pump
and new timing belt
Please someone help me with this weird problem
Old Jun 26, 2010 | 10:02 AM
OddityDX's Avatar
Default Re: Just turned my car on yesterday... with a problem...
check your clutch adjustment. I had that problem and that fixed it.
Old Jun 27, 2010 | 07:42 AM
Icon2 Re: Just turned my car on yesterday... with a problem...
Yeah I did that. I tightened it and nothing still has happened. Should I try to loosen it?
sodero
Aug 29, 2007 12:04 PM
Prudz_lude
Jun 25, 2007 06:18 PM
oemDC2
Apr 26, 2004 05:10 PM
erikgsr
Apr 6, 2003 12:03 PM
[626]95-GSR
Feb 15, 2002 09:25 AM
