ef ex brakes on a del sol si
i have a 90 ex sedan that i'm getting ready to scrap. It has da teg a rear teg disk conversion. I'm taking the rear rotors and pads off and putting them on my 93 sol si because they are the same and my sol's are worn out. I'm just wanting to have bigger brakes on the front of the sol and if i can use the 90 ex ones i will do that or whatever i have to use off the 90 ex to make it work since i already have the car. I'm also taking the 15/16th master cyl off the ex and putting it on the sol
ya gotta use 94-01 integra brakes for the front man if ya want to make em bigger. you can use all the rear on your sol from your ef. it's pretty simple just gotta swap the parts now brotha. good luck man
My sol is am si so it already has rear disks but the rotors and pads need to be replaced so I'm taking my new pads and rotors off my ef sedan.that sucks I can't use my fronts though
Xathine
Jan 28, 2009 01:25 PM
tylonalsnifnfool
Mar 23, 2006 07:50 PM
n2oef
14
Dec 20, 2004 01:18 PM
