Removing the Alternator
awrite so right now im changing the alternator on my ef, ive already unbolted the pivot bolt and the tensioner bolt.
my question - how do you get it out of the area?? i tried finding an opening from the bottom but the driveshaft gets in the way.
Just jack up the drivers side front wheel. This will lower the axle and you can then past it down thru.
Remove the master cylinder. Only two nuts and you can do it from above. Hands down, easiest method. Without disconnecting brake lines you can just hold it aside to pull the alt out.
--eclipse--
Jun 18, 2007 08:55 PM
ShakesTheKlown
Jun 12, 2004 02:24 PM
