!Help! Turboing D15B2 !Stuck!
Ok i am installing on a turbo on my d15b2 and i still need to do the conversion from dpfi to mpfi and go obd1. Where can i get ahold of the harness or what sort of suggestions do you have? i am looking to do this the easiest and least expensive way. Right now i got a pm5 ecu and everything from the si except the wiring harness. Also if i put some 450cc DSM injectors in it how do i wire it?
cheapest way is to convert it yourself, not pay someone to do it. it's only a couple wires, not that difficult.
http://hondaswap.com/swap-articles/d...writeup-49557/
what do you mean by how do you wire the injectors? make sure you have a resistor box for them and swap out the old injectors for the new ones. now as far as the ecu being able to use the bigger injectors you will obviously need to have the ecu chipped and tuned.
89ED
Jan 20, 2017 05:37 PM
beef-cake
Jan 23, 2007 08:10 PM
