building my b20 - few quick questions
Old Jun 25, 2010 | 02:17 PM
neverstop's Avatar
Default building my b20 - few quick questions
in the process of rebuilding my ~220whp b20 vtec, plan to spray it 50-75hp shot occasionally too. Few quick questions:
1. do I need to replace the timing belt tensioner oil and water pump? not trying to be a cheap *** but they probably have 15k miles max
2. anyone here think the Gates racing timing belts are better than oem?
3. will a b18b oil pan and pickup fit a b20 bottom end?
4. should I copper spray the head gasket? (i've never done this before)
5. will a stock crank pulley be ok? or I also have an unorthodox pulley I could use.
6. should I get arp main studs too?
Old Jun 25, 2010 | 02:43 PM
xzodiackillerx's Avatar
Default Re: building my b20 - few quick questions
1.IDK
2.IDK
3.Yes
4.dont need to
5.No
6.No
Old Jun 25, 2010 | 03:04 PM
neverstop's Avatar
thanks man, that pic in your profile is facking awesome too
not clear on what you mean by stock crank pulley no though? you're saying both stock and unorthodox shouldn't be used? what would you recommend then and why?
Old Jun 26, 2010 | 02:15 PM
sorry... use the stock pulley or a fluidampr
the pic is from this http://www.youtube.com/watch?v=x81iip6psks
Old Jun 29, 2010 | 08:23 AM
neverstop's Avatar
k, thanks
anyone think changing the tensioner and water pump is required?
Old Jun 29, 2010 | 02:24 PM
092eg6's Avatar
Barack Obama do THRILLER!!!!!
http://www.youtube.com/watch?v=dgJ4Q70FBWU
hbboostman
Mar 25, 2016 04:38 AM
vgsr
Dec 16, 2013 04:38 AM
horn12007
Aug 22, 2010 07:06 PM
treyh0lla
Jun 28, 2006 09:22 PM
Westrock2000
Jan 7, 2003 03:10 PM
