94 accord ex 5 speed got slower?
alright check this out. i recently droped my gear and messed up my car. then my car got messed up and was misfiring horribly then i took it to the shop and they said its my spark wires so then i changed it. and they fixed it. i was so sure it wasnt the spark wires that got my car ****ed up i think it was the engine ok. then then another day i burnt my clutch then replaced it. and now after i got my car back it feels like it slowed down alot more and the clutch doesnt feel like it should it feels very light when i clutch into gears. when i try to go fast from 0-60 it feels like its takes longer then it normally does. any ideas? also my steering wheel started shaking when i drive it. thats a differnent subject.
Alright, I'm checking it out.
What does 'droped my gear' mean? I'm a little confused here.
It got messed up after you droped the gear, and then it got messed up again? Define messed up.
What did you change and what did they fix? It's a bit unclear here.
First you droped the gear and messed up the car. Then the car got messed up again. And now the engine ****ed up the car?
Got that.
Don't step on the brakes so hard. Then the car won't slow down as much.
Maybe you put in a different clutch with a softer pressure plate, compared to the one you had before.
Try going fast with <1/4 tank of gas. With a full tank it will take longer.
Yes it is.
03cbhonda
Nov 19, 2014 01:00 PM
