H22 Timing belt tensioner question
I am doing the auto to manual swap and just wanted to know instead of using the long bolt that is used. can i use a bolt like in a B or D series? i have eliminated the balance shafts so no need for the pulley. Please let me know.. thanks
the balance shaft kit came with the lower gear replacement part as well. So i think i am good there. So for the spacers i should use them behind the timing belt tensioner? Thank you for the help..
