Upgrading Axels For FI Setup
Old Jun 25, 2010 | 10:56 AM
azandford's Avatar
Default Upgrading Axels For FI Setup
My ek is making the power in my sig. Im looking to run Mickey Thompsom ET for street tires and am afraid im gonna ruin my stovk axles with these tires. I was looking for some better axles around 500 bucks. The only thing i have been able o find aftermarket that wasnt a like a grand was hasport stage 1 axles but there only rated for 200whp. Hoping you guys can shed some light on this for me. Thanks
Old Jun 25, 2010 | 12:10 PM
azandford's Avatar
Default Re: Upgrading Axels For FI Setup
bump
Old Jun 25, 2010 | 12:47 PM
Nichelson_Performance's Avatar
Dude just run remanufactured stock axles...I'm making roughly 290 whp at 14psi and I tracked my car with bfg drag radials with 10psi in them on stock axles and it was fine and last year on 20psi b4 my rings went and I was well over 300whp with stock axles no problems at all.....just load the driveline by slipping the clutch before you launch.....aftermaket axles on a 300whp is a waste of money
Old Jun 25, 2010 | 12:52 PM
cleansi's Avatar
there are alot of people out there making 500 plus whp on stock axles there really is not much of a need to purchase aftermarket ones as long as you preload your axles you should be fine, you will break the cv shaft boots eventually but its alot cheaper then buying shop boys hasport axles ect...
just my opinion i would spend the money else where
OG undercover
Dec 16, 2006 06:22 AM
92gsrteg
May 10, 2006 03:40 PM
carblegal
Mar 28, 2003 04:57 PM
hybrid901
May 23, 2002 06:28 AM
HybridMT
Nov 1, 2001 09:05 AM
