F20b timing belt?
Old Jun 25, 2010 | 07:34 AM
crxsleeper210's Avatar
Default F20b timing belt?
Does anyone know where/if I can purchase a new F20B (DOHC VTEC) TIMING BELT (156 TEETH) Honda part number 14400-PCB-004.....The reason I ask is because I will be doing the Manual tensioner conversion in a couple months when i get my new H22 and I heard that this belt is a perfect fit as oppossed to using the h22 belt (which i know works fine) which is a tighter fit....
Old Jun 25, 2010 | 09:23 AM
Default Re: F20b timing belt?
No one has any links to get euro OEM parts???
Or any link to get this specific part???
Old Jul 1, 2010 | 10:11 AM
wow that is amazing....so the f20 dohc vtec timing belt isn't available thru someone here in the usa????
Old Jul 1, 2010 | 11:29 AM
Tunerguy1989's Avatar
ya i guess not, is it worth the hassel how much a of a better fit will it be?
Old Jul 1, 2010 | 01:28 PM
Well i have nothing but time for my motor build and if i can get a hold of THE RIGHT parts for the manual timing belt conversion then I'd rather take my time and source them down then get a regular h22 tb and "make it work"...i know its not a big deal but like i said im not in a rush and all i need is a link to a website or something
Old Jul 1, 2010 | 01:44 PM
megomaniac's Avatar
after changing my belt a couple times, its not that hard.Snug fit but it's fine. I have h22a4 with manual tensioner.
had to change out brand new belt cause one of the bolts for the adjustable cam gear ate it....
Old Jul 1, 2010 | 01:54 PM
bryen813's Avatar
I've had alot of trouble finding euro specific parts in the states too. good luck with the search
Old Jul 6, 2010 | 12:51 PM
BUMP....Anyone have connections to get Euro spec parts????
Old Jul 6, 2010 | 01:43 PM
92civlude's Avatar
hmotorsonline has brand new timing belts for F20b. They are in the "WHATS NEW" section. BB4 prelude parts.
Old Jul 6, 2010 | 02:32 PM
THX....its a little high on the price but exactly what i was looking for...anyone else got any links for euro spec parts?
Old Jul 7, 2010 | 02:37 PM
Apex1972's Avatar
so does anyone here know for sure if this is true? So,the H22 belt is 155 teeth? will this even work?
Old Jul 7, 2010 | 02:41 PM
judgeDredd's Avatar
yes the h22 timing belt works ive been using one on my f20b for 2 years now its a tight fit especially if you have a auto to manual tensioner conversion
Old Jul 7, 2010 | 04:31 PM
92civlude's Avatar
Yes, the P13 belt does indeed have 155 teeth. The size code is 155YU24. If that helps.
Old Jul 10, 2010 | 12:44 AM
EG6 Master's Avatar
Greetings From Tokyo!!!!
From one fellow F20Ber to another.....
Greddy Timing Belt--- (Part # : 13554504)
http://eshop.supergt.com.hk/search.p...del=cf4&bname=
Nengun--You must create an account in order to order/bid
http://www.nengun.com/auction/item/v149082492
RHD Japan
http://www.rhdjapan.com/honda/accord...g-belts?flag=1
Old Jul 10, 2010 | 05:13 AM
Apex1972's Avatar
no, I think the OP was inquiring about the F20B belt on an H22. this is because of using the manual tensioner a longer belt would be easier to install. maybe I read it wrong but I would like to find out as I am nearing my service interval and I will get an f20B belt for my H22 if it indeed fits properly. thanks guys
Old Jul 10, 2010 | 06:27 PM
EG6 Master's Avatar
you are correct. didnt read thoroughly.
Old Jul 15, 2010 | 11:06 PM
TheJGB3's Avatar
Here is a Honda dealer in the UK that sells it
http://www.lings.com
they want 61 quid (British pounds ~$94 USD) for one
Old Nov 9, 2010 | 05:25 PM
Apex1972's Avatar
http://www.lings.com/lingscentralapp...5684MxKGq8BFFC
Old Nov 9, 2010 | 11:31 PM
pentaq's Avatar
Try to ask here: http://www.autodynamics-honda.com They have some OE rare stuff.
H22LUDE808
Mar 7, 2008 09:18 PM
MugenLudenB00st
Oct 4, 2005 02:35 PM
