iat sensor
Old Jun 25, 2010 | 12:54 AM
CoastalSi's Avatar
Default iat sensor
Are there any huge issues when the IAT sensor is disconnected?
Old Jun 25, 2010 | 01:02 AM
Dead CIVIC's Avatar
Veteran: Army
Default Re: iat sensor
no... not that i know of.
Old Jun 25, 2010 | 11:18 AM
D16SiHatch's Avatar
why do you ask though..?
Old Jun 25, 2010 | 11:22 AM
supratin's Avatar
Check engine light.
Old Jun 25, 2010 | 12:15 PM
CoastalSi's Avatar
No CEL.
I'm using the USDM p72 Type-R Intake Manifold on my JDM b16a and the sensor outlet on the IM is being blocked off by the stock fuel rail. The IAT sensor is dangling in the engine bay and it should be taking temperature readings from the engine bay...I think.
Old Jun 25, 2010 | 12:16 PM
4g4dcruisin's Avatar
Um, yes, air:fuel gets all jacked to ****. Plug it is, or do what you have to do to get it working again.
Old Jun 25, 2010 | 12:41 PM
CoastalSi's Avatar
My goal is to get this baby BAR'd. I know they changed a few state emissions laws. 4g4dcrusin, I read your post a couple days ago about the new BAR-ing laws. Is it still possible to BAR a JDM b16a?
Old Jun 25, 2010 | 12:53 PM
I've heard the california state laws say that japanese vins are not accepted. Also, you can only have a motor that was in the same model as yours. I dont know if they look into trim level.
US
-dx
-lx
-ex
-si
Japan
-siR
So if you have an obd0 siR I motor, you might be alright considering it came out of an 88-91 civic. But honestly im not too sure.
Old Jun 25, 2010 | 01:00 PM
CoastalSi's Avatar
Cali laws are getting real stingy. So people with Type-R,GSR.. EF's aren't BAR-ing these days? edit: wait, so ALL jdm motors, regardless of model, are pretty much illegal; no matter what.
Old Jun 25, 2010 | 01:11 PM
crx_si-r's Avatar
Jdm motors are allowed as replacement motors once your car has been reffed to carry that engine type. In order to bar a new motor in your car it has to be a usdm model.
Also to the OP you need to have a type r fuel rail, which relocates the fuel pressure regulator, and allows for clearance of the IAT. also a type r is not a p72, it's a P73.
Your set up should look similar to this....
This is my first gen skunk2 manifold (copy of a type r) with type r fuel rail and injectors.
Old Jun 25, 2010 | 01:26 PM
CoastalSi's Avatar
What about the GSR OBD1 fuel rail, will that fit?
JPat
Honda Civic (2001 - 2005)
Apr 22, 2018 07:09 PM
Aaron Cayabyab
Oct 7, 2012 03:23 PM
quik89
Nov 29, 2003 08:53 PM
