Car not running right
Old Jun 24, 2010 | 11:36 PM
dragonkx's Avatar
Default Car not running right
hi, well i have a 2000 honda civic si b16. I modified it to have a compression that is higher or close to a integra type r with stock b16 pistons. well my problem is that from time to time the car has response lag. i beleive. like when im in first gear, full stop, when i accellerate to go it doesnt really go, kinda feel like its almost hopping by. the car would feel like it lost power then get a jolt then lose it. its does happen throughout all the gears but more frequent on 1st gear. im currently running on obd2 ecu. Any ideas?
Old Jun 25, 2010 | 06:12 AM
jdm_head's Avatar
Default Re: Car not running right
check the dizzy wiring ma b bad or cap rotor, check spark plugs ,tps sensor the small stuff also do a compression test if all is fine there get a tune ecu for ur car
Old Jun 25, 2010 | 10:42 PM
dragonkx's Avatar
well at first the distributor was bad litterally died, replace it with a cheap ebay one. checked sparks all were fine as far as i can tell. the sensors on the throttle body are all there as far as i know and tuned properly with volt meter. my compression was around 230 psi so should be fine. but just dont know why car chugs sort of say.
2001CRV
14
Oct 16, 2017 06:51 AM
stevenDAtegra
Jul 17, 2009 07:30 AM
slammedEG1994
Dec 21, 2006 05:44 PM
erebunicrx
16
Nov 12, 2005 03:02 PM
dazz
Feb 21, 2003 01:22 PM
