where is the crank position sensor???
Old Jun 24, 2010 | 11:13 PM
Godspeedmj's Avatar
Default where is the crank position sensor???
i have a 94 civic ex.... my cel is on and its throwing a code 4. wont let me rev past 3100k... i replaced the dizzy and tryed other p28 ecu's but no luck. any help would be appreciated
Old Jun 25, 2010 | 03:29 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: where is the crank position sensor???
The CKP is in the distributor. Check wiring for damage and continuity.
Old Jun 25, 2010 | 03:43 PM
Godspeedmj's Avatar
ok i check the wiring and oms everything looked fine. how do u check for continuity?
Old Jun 26, 2010 | 02:44 PM
Godspeedmj's Avatar
bump
Old Jun 26, 2010 | 02:59 PM
Nichelson_Performance's Avatar
thought the cam sensor was in the dizzy
the crank sensor is behind the timing belt cover
Old Jun 26, 2010 | 03:25 PM
BryanM.'s Avatar
Resident Gearhead
For '92-'95 Civics the CKP is found in the distributor. OP has a '94.
The '96-'00 Civics have the CKF right at the crank, behind the timing cover.
Old Jun 26, 2010 | 04:46 PM
Godspeedmj's Avatar
so how do u check for continuity?
Old Jun 27, 2010 | 03:03 AM
BryanM.'s Avatar
Resident Gearhead
Multimeter will work. Basically just see if power is reaching the sensors.
GhostAccord explains it well:
Originally Posted by GhostAccord
I would assume that the CKP sensor in your D16Z6 Civic is probably in the distributor. Not the same as the OBD2 Accord posted above. If the CKP in the distributor goes bad that means you will need to replace the distributor.
There is a test procedure
• Disconnect the 8pin connector from the distributor
• Measure the resistance between sensor terminals B & F (ECU terminals B15 BLU/GRN wire & B16 BLU/YEL wire)
• If the resistance is not between 350Ω & 700Ω replace the distributor.
• If the resistance is between 350Ω & 700Ω - Check for continuity to body ground on both B & F terminals.
• Does continuity exist
Yes - replace distributor
No
• Test the ECU
Remeber to SEARCH! I found this info right here on H-T on the first try!
Old Aug 5, 2010 | 03:06 PM
Nivek533's Avatar
Hi I've Got a 94' Accord ex and the MIL is saying that it is the Crankshaft position Sensor, is there any parts place that sells JUST the Sensor its self....I've tried local parts stores but no luck....Does anyone have a picture of the sensors location IN the Distributor????????????
Old Aug 6, 2010 | 06:55 AM
teamfdudb7's Avatar
bump.................
Old Aug 6, 2010 | 09:01 AM
forcefedferio's Avatar
Try the Accord forum, you'll get a more focused knowledge base there and i'm sure one of the Accord guru's has a picture they can share.
Seriously, stop bumping every thread you open, it's pointless and annoying.
Old Aug 9, 2010 | 06:57 PM
Godspeedmj's Avatar
the dizzy works and it has continuity. so i just sprayed tb cleaner in the intake and it revs to almost 6k does this mean i have a fuel problem and the ecu is just throwing a code 4? any ideas will help thanks
Old Aug 9, 2010 | 07:01 PM
Godspeedmj's Avatar
ttt
Old Oct 26, 2010 | 12:08 PM
edua_pp's Avatar
I have a problem with my honda civic, he had a D16Z6 engine and had to replace a d16y7, when making the adaptation everything is in place but not functioning, the CKP d16y7 engine is next to the band's time and D16Z6 distributor of the CKP signal gives the different and this dealer, I can do to solve the problem??
Old Oct 26, 2010 | 12:28 PM
94EG8's Avatar
Seagull Management
What? If you're putting the engine in a '92 - '95 Civic use a D15B7/D15B8 distributor, don't worry about the CKF sensor an OBD1 ECU wont look for it.
Old Oct 26, 2010 | 01:09 PM
edua_pp's Avatar
D15B7 is a distributor. Then supposed to have problems in terms of the signal received by the ECU? Because the motor d16y7 brings a CKP sensor connector with the timing belt must be disconnected?
You can not start my honda, gives up but can not turn on
Old Oct 27, 2010 | 05:31 AM
edua_pp's Avatar
D15B7 is a distributor. Then supposed to have problems in terms of the signal received by the ECU? Because the motor d16y7 brings a CKP sensor connector with the timing belt must be disconnected? so the problem is not in the distributor? what can i do?
You can not start my honda, gives up but can not turn on,
Old Oct 27, 2010 | 05:42 AM
94EG8's Avatar
Seagull Management
So long as you're using an OBD1 ECU it wont look for the CKF sensor behind the timing cover.
Old Oct 27, 2010 | 06:09 AM
edua_pp's Avatar
my ecu is p28, that means that the wiring if I serve and are supposed to turn on the deep ..? Certainly not understand, if the cable CKP this band next to the distribution must be connected to the output of the distributor?
Old Oct 27, 2010 | 07:52 AM
94EG8's Avatar
Seagull Management
I'm guessing english isn't your first language, if you're running this through a translator like bablefish or google its not getting the point across.
But again, don't worry about the CKF sensor, the ECU wont look for it.
Old Oct 27, 2010 | 10:20 AM
edua_pp's Avatar
yes, my english not is my first lenguaje, an apology
so, what can be not start engine my honda? if everything is conected in your place. You have some idea?
Old Oct 27, 2010 | 10:30 AM
edua_pp's Avatar
maybe, change the wiring from my distributor?
for that can get the signal for my distributor to the ecu p28?
jetlife
Sep 17, 2016 10:43 AM
padlock1978
Apr 12, 2014 03:32 PM
2000siturboR
Nov 6, 2009 03:29 PM
SwappedLSHatch
Apr 13, 2006 01:33 PM
nayrone
Nov 1, 2004 07:21 PM
