HELP! B18B1 block/B20 head - low, rough idle and adjusting idle screw doesn't help
Old 10-25-2010, 07:32 PM
BeaNBMX06's Avatar
Default HELP! B18B1 block/B20 head - low, rough idle and adjusting idle screw doesn't help
I have a 99 hatch. It has a B18B1 block w/ B20 P75 head. Vehicle consitently idles at around 500rpm. Motor idles rough and its aggrivating. I tried adjusting the idle screw on the throttle body and its only a temporary fix until the next time I start it up. Let me know any ideas.
Old 10-27-2010, 03:54 AM
lokiko's Avatar
Default Re: HELP! B18B1 block/B20 head - low, rough idle and adjusting idle screw doesn't hel
I remember reading something somewhere that you have to unplug the iac valve, set your idle, and then remove and install the backup fuse in you engine bay fuse box, plug in the iac, and restart the car.... its been a while but I think that worked for me..
Old 10-27-2010, 10:46 AM
BeaNBMX06's Avatar
Thanks
Old 10-27-2010, 10:48 AM
BeaNBMX06's Avatar
My IAT sensor is not connected, would this be a factor in my idle?
EJ1A1
01-06-2017 12:07 PM
expressivepinoyboy
02-19-2009 05:37 PM
teamXteg
06-13-2008 11:08 PM
jetlude
08-01-2006 11:09 AM
Quick Reply: HELP! B18B1 block/B20 head - low, rough idle and adjusting idle screw doesn't help
