hit a curb, bent subframe
Old Jun 24, 2010 | 06:09 PM
mattbatson's Avatar
Default hit a curb, bent subframe
that is what it looks like the previous owner did.
I had to replace the original rims because they were wobbling.
After I did this the car was pulling left, so took it in for an alignment and one side of the front has way more positive camber than the other side.
I appears that I may have a bent subframe, as all the other suspension pieces look good.
Should I take it into a frame shop and let them straighten it, or buy a new one?
I heard that a new subframe is only about 350....anybody ever do this?
thx
Old Jun 24, 2010 | 07:24 PM
BrayzieEF9's Avatar
Default Re: hit a curb, bent subframe
front or rear subframe???
Old Jun 24, 2010 | 07:55 PM
BiG ChOr!Zo's Avatar
you can get a used subframe from craigslist or the junk yard for pennies on the dollar...!!!
Old Jun 24, 2010 | 08:04 PM
BrayzieEF9's Avatar
front subframe is easy ,rear subframe is meh
Old Jun 25, 2010 | 05:53 AM
mattbatson's Avatar
it is the front, and I had heard they arent too difficult to do.
I'm just wondering if I should risk a junkyard or craigslist. I might end up with another bent one.
Maybe just have a frame shop straighten it out for me?
Or buy new...
Old Jun 25, 2010 | 06:04 AM
BrayzieEF9's Avatar
the front subframe is detachable just unbolt it and get a new one from the junkyard.you might need to get your frame straighted if the new subframe doesn't bolt up.
Old Jun 25, 2010 | 09:53 AM
michael-crxsi's Avatar
What is the subframe?
Old Jun 25, 2010 | 09:58 AM
BrayzieEF9's Avatar
the frame that holds your suspension components
Old Jun 26, 2010 | 04:53 AM
Eximious's Avatar
The large black pressed steel frame that keeps the front of the car stiff and mounts the lower control arms. On the front you have 2, 1 that keeps the front chassis legs together adn 1 that holds the suspension and steering gearbox assembly.
Old Jun 26, 2010 | 04:57 AM
EFRue57's Avatar
aka - front crossmember
go to the junkyard, find any 88-91 civic, check to make sure the cross member is not bent, then it's only 4 17mm or 19mm
(i believe they are 19mm) bolts that hold it up plus the 2 per side 17mm bolts that hold the radius rods to the lower control arms. so 8 bolts total. shouldn't take you more than 10 minutes tops.
Old Jun 26, 2010 | 09:18 AM
BrayzieEF9's Avatar
if its your crossmember then your probably gonna need to get your frame pulled if it was as bad as my wrecked ef,check my build thread for reference
Old Jun 26, 2010 | 02:49 PM
88EFrex's Avatar
i have both pieces of the front subframe if u need them let me know
Liloyo
Aug 28, 2013 12:08 PM
marcBBC
Acura TSX
Jan 10, 2011 05:40 PM
static-x
Suspension & Brakes
Jan 7, 2010 02:31 PM
jchrm80
Suspension & Brakes
Oct 8, 2007 01:45 PM
EF Two
Jun 20, 2006 06:47 PM
