what head on LS(B18B) block for turbo
I have an LS bottom but no head. I need a head and want to know what my best choice is. i dont want a vtec head because of the high compression and they are pricey.
so far i think my choices are:
* B18A head - i dont know if that will work and what the compression will be
* B18B
* B20 - also dont know if that will work and what the comression will be.
which will be my best choice for compression, availability and price
* B18B
Vtec motors only have high compression stock due to the piston... head has some play in it, but very little.
The B18A and B18B heads should yeild the same CR on the block (if the head is not milled) But the B18B has a more efficient head and I/M design, which yields more Hp.
If you have a choice, opt for the B18B.
Isn't the B20 head and the B18B head the same?
X2
Jillianbowman87
16
Oct 17, 2011 01:24 PM
juicedricer
19
Jan 19, 2011 08:37 PM
