95 Accord Shaking
I can t find whats the cause of my 95 5speed accord shaking on 1st and 2nd gear. I replaced the upper control arms lower ball joints outer tie rods inner tie rods and sway bars. I took it to meineke for an alignment and they said that it wouldnt stop the shaking. Anyone have any suggestions? Ive been told to the alignment tho and the wheel balancing. !@#$%$#???
the car is shaking? hondas have small tires... getting a balance dont be very noticeable in 1st or 2nd gear. does it continue to shake if you push the clutch in? or does it only shake when under power?
Mine shakes when accelerating usually after the car has sat overnight, I know what the issue is and it's my clutch.
I am certain there is oil leaking onto the clutch disc (probably from a rear main seal leak). when I throw it into 1st gear car shakes but once warmed up it stop.
Sorry this could be unrelated to your issue thought I would throw it out there as thought.
hmong337
Nov 11, 2012 03:56 PM
EK FLY
Jul 5, 2011 05:15 PM
hondaracer4vtec
Jul 29, 2008 05:56 AM
