RPM Lead Signal Wire
Car is 2000 Civic Cx hatch and motor is 2000 GSR b18c1. I got the RPM lead signal wire left on the distributor, it's the dark blue wire and there isn't a hole for that wire on the pigtail. Does anyone know if I need to splice this wire somewhere or whether this wire goes straight to the ECU? I don't see a pinout for it on the ECU. Need help soon because I have to BAR this set up soon. Help much appreciated!
i had a similar issue i ran the signal wire @the dizzy 2 the driver side on the engine bay theres a small wire thats blocked off by a rubber piece which is a blue wire thats the rpm signal its near ther cruse control sys near the driver hood hinge
There such a wire on the 2000 civic harness? Reason I ask is because the 99-00 civic doesn't have the rpm signal wire like the gsr. Thanks for help jdmhead, much appreciated.
what ecu were you use if at the time??
Weifast
Jul 16, 2014 07:17 PM
T25 civic
Oct 6, 2002 02:11 PM
