HELP!!! D15B2 Stock Auto Tranny
I have a 1991 Honda CRX DX with the stock auto tranny. The car does fine in 2 and D3, but as soon as i put the car in D4 and try and drive at a normal speed it unloads and reloads in about a second. Idk what the problem is and i dont have the funds to do a 5 speed swap. I just wanna fix my current problem and have a good running car.
What does "try and drive at a normal speed" mean? How fast are you going? Are you accelerating, decelerating, or holding a steady speed? What gear is the transmission in when this problem occurs? Does it only happen when the trans shifts to 4th gear, or does it happen in 2nd or 3rd? What does "unloads and reloads in about a second" mean? Does the trans shift hard or violently? Does it shift slow or hesitantly? Is it shifting into all four gears? Do the revs flare up momentarily when the trans selects the next gear?
