Over-sized P73 Pistons what head gasket?
Hi Guys,
I'm wondering what bore head gasket to get with .25mm over sized USDM P73 pistons? Does anyone have experience with this?
The only thing I see online is 81.5mm bore head gaskets. Will that work for this build? I measured my stock head gasket and the bore was 81.6356mm.
When they list a head gasket at 81mm is that the bore on the gasket itself or the pistons it will support?
Thanks in advance!
Thanks in advance!
Stock fits just fine.. Even the factory service manual doesn't call for an oversized gasket on size over pistons. The factory gasket has enough room that it isn't an issue
