94 Accord M/T Cruise control works only when its hot outside? What the ????
Old Jun 23, 2010 | 05:55 PM
UR2NOZ's Avatar
Default 94 Accord M/T Cruise control works only when its hot outside? What the ????
Ok so I have used the search function but with no avail to my issue. On the way to work when the it is cool outside I cannot get the cruise to engage for nothing. The light on the actual cruise switch does work and the green "cruise" light on the cluster lights up for about one second each time i push the button on the steering wheel. Now every day like clockwork when I leave work and it is warmer outside, I set the cruise on the way home and all is well? However I will say sometimes it sets then drops speed quite a bit while on cruise, other times this doesn't happen. So does this sound vac related? If so I have located the cruise unit and the majority of the lines under the hood and they all look to be complete with not cracks ect.
Any advice appreciated
Adam
Old Jun 26, 2010 | 12:56 PM
mnizzy's Avatar
Default Re: 94 Accord M/T Cruise control works only when its hot outside? What the ????
I have the same problem on my '92 lx... i'm pretty sure it's a vacuum leak somewhere that seals or something when it warms up outside, but i haven't had time to look at it lately.
If anyone else has experienced this i'd be interested in any advice you might have as well
Nealva
Oct 12, 2016 04:23 PM
Hawkeye616
Jan 2, 2015 04:42 PM
goldenmustache
Feb 6, 2012 06:18 PM
A Tribe Called Honda
Feb 28, 2007 02:53 PM
gen4acclude
Feb 15, 2005 07:07 PM
