any one knows results about any b16a with b18c head?
From: santo domingo, santo domingo, dominican republic
i would like to know if any of you have use a b16 block with a b18c head, does any one know the C.R. it would be? the block is a b16a1 ....
Assuming you're talking B18C1 head, with pr3 pistons in your b16a, you should be looking at a compression ratio of 10.446~ although you will lose around 8cc displacement...
Why not go for some ctr pistons and rods whilst retaining your b16a head... it flows better anyway, that ought to give u a 10.8:1 compression.... if u add the b18c1 head, its 11.0 compression on your b16a... all with oem goodness mmm...
