calling all who have done a b series swap
alright so i have pretty much gutted the entire car for paint/b series swap... i have been working on removing the harness from the engine bay and find myself stuck... i have removed the engine and disconnected all plugs under the hood and removed them from their zipclip mounting point.
what i am having issues with is how to pull the harness through the fire wall it seems to run the whole width of the car on the inside and i cant seem to find the end of it... looking for some help has anyone done this before or am i doing way to much work than its good for? thank you
i have not removed the air passages yet but yes that is the part of the harness, mainly the part that heads toward the drivers side that i am having a hard time with
If you do all this, you might as well wire tuck everything under the hood. If you have the time and the patience, have at it.
I left my harness all alone and everything is still fine. I didn't remove anything that I didn't need.
its the same as the passenger side. just push on the boot thats on the firewall and it would simply go into the cabin.
