plug wires and sri
ok 97 f22b1 i have a misfire replacing plugs and wires what are my options i can only find msd 120$!!! or ngk 50!!!! and what type of plugs would u recomend and cai or short ram gonna get an ebay kit and put k&n filter on it just ur opinions please
Are you sure you have the correct firing order with the cables?! There are more options other than ngk and msd, you just need to visit a local auto parts store.
OEM or OE equivalent replacement for the spark plugs and wires is good. CAI will get you slightly colder air than SRI, be sure to add one of those joints that keep the engine from sucking water in (if you decide to go with CAI). I have a SRI and it's fine, never had a problem with hydrolocking it even driving through a street that had water up to my headlights.
you just want opinions... my opinion is you should organize your thoughts better before you post. try breaking things up into sentances and even paragraphs.
example:
you apparently have detected a misfire [by magic or by checking the stored code(s)]. you have decided that replacing the plugs and wires will fix this. [possible; couldn't hurt]. you would like to know all your options. here are two options you've found so far- MSD wires for $120 or OEM NGKs for $50. [one seems awful tempting for anything short of a dedicated track car...] you're also unsure of what plugs to get. [seems you've overlooked the label on your hood and in your owners manual listing the NGK part number suitable for your engine (hint: ZFR6J-11)].
additionally, you are wanting to install an aftermarket intake. you plan to buy an eBay kit and replace the Chinese filter element with a K&N brand [savvy!]. however, you're having trouble with the search function and are unable to find the hundreds of threads on SRI vs. CAI. [i'm sure you'll catch on eventually]
you're in search of opinions only and you appreciate any guidance you receive. thanks.
ok douche bag i wanted honda owner opinions not some guy with a ls1 deeeerrrrrrr thats why its not reliable to search the web dont have an owners manual so ur a retard again keep ur mouth shut its my first honda little girl
I would do NGK plugs and wires. I'm currently running the NGK plugs in my H, and also I went from 2.25" intake piping(AEM) to 3" SRI(Ebay) now that I'm rocking my S2 Pro2 cams; need more air flow. Get a 3" if you can; the Honda 2.2L needs to breathe.
this guy's acting like a troll...
Well, I know where you learned how to write (grade school, and hopefully not an American one), but I can't figure out where you learned how to be a complete tool. Did you have to pay a lot? Because you seem to have a world class education in that area...
Everything you just said makes no sense and has turned everyone against you. You have no right to call anyone else out on knowledge if you can't even find proper spark plugs.
Regardless of what you think of Hondamark35, he did give you some good advice to start with. That's way more than you'll get from me after seeing those trashy posts.
CBR600OnTop
Feb 15, 2003 10:35 PM
