Timing belt replacement
i dont know what year(s) it was for but i saw a video on youtube about this. try searching that. just fyi i think it can be a pretty difficult job if you dont know what you are doing.
edit: did not realize i added the link to favorites
lucky you
here is the link
http://www.youtube.com/watch?v=EmasxgJdXJ8
lucky you
here is the link http://www.youtube.com/watch?v=EmasxgJdXJ8
You can probably follow the 90-97 Accord writeup. It is about the same. You can buy a complete writeup from this YouTube person, he goes step by step. I saw it on his website http://www.ericthecarguy.com/fix-it/ I never seen the video, but his other videos are really detailed and he shows you tips.
For me, I used the DIY 90-97 Accord Timing belt change (in the Accord FAQ) when I changed my 01 Accord timing belt
just use my write-up in the FAQ, it's better than that video
seriously though, you can print the instructions from a PDF download that is linked in the write-up, that way you can have it with you while working on the car.
Timing belts are very important. They control the valves and pistons of the machine. If the timing belt should break pistons can drain valves, which break the engine in a way that would cost much expenses we are talking about 2000-3500 dollars. Your car is about twice the mileage that the timing belts should be replaced. Consider that you have a sense.
lucky you
here is the link
lucky you
I followed this video and some guidelines from the Honda Accord repair manual and was able to succesfully replace the timing belt on my F18B3. I never did a timing belt before on any car. This video is very helpful.
Two400
Jan 22, 2008 04:10 PM
swapped95
Oct 13, 2006 08:27 PM
Goofyboy
Oct 19, 2004 06:25 PM
