Which one is better?Steel or aluminium flywheel?
Old Jun 23, 2010 | 08:11 AM
ekcivic2's Avatar
Default Which one is better?Steel or aluminium flywheel?
Hi everyone,i have a civic 97 with a d15 engine,and just as my clutch is dying,am about to buy a stage 1 clutch kit with a flywheel,but don't know which one is best?The options available is either i buy the steel flywheel 8.5 lbs or aluminium flywheel 7.5 lbs?so could you guys help me in choosing the best one,the more reliable one?Thanks.
Old Jun 23, 2010 | 08:30 AM
Gunmetal_B20_Hatch's Avatar
Default Re: Which one is better?Steel or aluminium flywheel?
It doesnt really matter...
Old Jun 23, 2010 | 09:02 AM
ekcivic2's Avatar
Then,what would you advise me?
Old Jun 23, 2010 | 09:07 AM
nothing_shocking's Avatar
The lighter it is the faster you have to shift. Mine is a 7 lb aluminum Fidanza and I absolutely love it. Also have a short shifter. As far as material goes, I don't really think it matters. They're both good. I'm gonna guess you're talking about the kits on eBay?
Old Jun 23, 2010 | 09:35 AM
ekcivic2's Avatar
right,there is a package including the clutch kit on ebay.now in terms of performance,is a noticeable difference between the 7.5 lbs and 8.5 lbs?
Old Jun 23, 2010 | 09:55 AM
Lionsmane38's Avatar
you may notice a small difference in shifting, but a lot of it comes from the short shifter and the clutch assembly itself. I just installed an Exedy Stage 1 with their lightweight flywheel when I swapped the s4c w/ lsd into my em1. The combination of all of it made quite the difference. I would definitely advise not going with Ebay kits though.
Old Jun 23, 2010 | 09:59 AM
JDM_SOHC's Avatar
I had an XTD Stage 3 ebay clutch/flywheel kit for 2 years with no issues, so I'd highly advise you do go with ebay and save yourself a couple hundred dollars... Lifetime warranty as well...
Old Jun 23, 2010 | 10:05 AM
92bseries's Avatar
hahahaha^^^^^ ebay **** is garbage, DO NOT buy anything from ebay, u will end up buying a replacement sooner than later if u buy something from egay
Deetz's Avatar
Crazy Honda Guy
I have used a number of setup's...my opinion for experience......
Go with good quality parts, after all, they are your drive train, important stuff!!!
ACT makes some of the very best flywheels out there for the money. They are strong and will "last"
Clutch, "always" go with a good brand!! ACT, Exedy, Centerforce, Clutchmasters are my favorite brands. Sure, all clutches work, and other will tell you they do, but the better brands work "better"
They have better drive characteristics, can last longer, and have smoother engagement. Also important!
Old Jun 23, 2010 | 10:06 AM
Yeah, I've had 3 ebay clutches so far. One xtd stage 3 (on boost), a stock replacement and an F1 Racing stage 4 (on boost) and I've never had a problem with them. Ebay stuff seems like it's gotten better over the years... Wouldn't trust the suspension stuff yet though...
I would have loved to go with a big name brand, but I decided to save $400 on the clutch for a stock motor on low boost. Once I get around to building something, you better believe I'm going with a high quality clutch.
Old Jun 23, 2010 | 10:09 AM
92bseries's Avatar
dont trust ANYTHING from ebay
Old Jun 23, 2010 | 10:10 AM
JDM_SOHC's Avatar
Obviously you're more ignorant than you are intelligent, my clutch/flywheel outperformed my ACT and Exedy, next time study before you speak..
Old Jun 23, 2010 | 10:12 AM
JDM_SOHC's Avatar
I was boostin 12psi for about 2 years with my XTD kit and I never had one issue... I did a writeup a while back on a "Budget Build" with all ebay parts "some name brand parts also but they were bought off ebay" and it definitely surpassed my expectations... I'd recommend XTD to anybody I come across, top quality for low price...
Old Jun 23, 2010 | 10:16 AM
kaiba's Avatar
Stop labeling Ebay as a brand name.
Old Jun 23, 2010 | 10:20 AM
JDM_SOHC's Avatar
Stop typing before you thoroughly read...
I said I bought NAME BRAND PARTS off of Ebay, "Golden Eagle, Skunk2, Garrett, JRC, RC Engineering, etc"...
The genius's are out in full force today I can tell...
Old Jun 23, 2010 | 12:43 PM
kaiba's Avatar
I'm referring to the other idiots.
j.orr
Mar 29, 2009 06:22 PM
PWRDbyHseries
Mar 26, 2007 06:19 PM
PBAndrew
Mar 12, 2007 08:04 PM
eg4life1202
Dec 29, 2006 11:28 AM
syshs
Jul 28, 2006 08:26 AM
