Car to low for alignment rack
Old Jun 22, 2010 | 05:14 AM
Reyracer19's Avatar
Default Car to low for alignment rack
So took my EK to Tires Plus for alignment a few weeks back and noticed they had a very hard time with the rack, they had to get 2 guys to lift the the rear by the fender well on each side to drive it onto the rack...Needless to say I looked at them with horror from the other side of the glass in their waiting room.
I'm only tucking the front just a bit but the back still has like a 2 finger gap.
Note: They laid out some pieces of wood on the floor as I knew they should have handy for lowered cars.
Should some place have like an in ground rack or a better system to get this done?
Old Jun 22, 2010 | 05:36 AM
Vindicator9000's Avatar
318 Curves, 11 miles
Default Re: Car to low for alignment rack
It's common. I've heard horror stories. Tons of places will give you all kinds of hell for even moderately lowered cars. I try to stay away from places like that because it indicates that they don't really have a clue about the theory behind suspension geometry.
I'd think they should have some planks or something though.
Old Jun 22, 2010 | 06:04 AM
apexi_rsx's Avatar
just take it to the dealer they never fussed about mine and its only 60bux
Old Jun 22, 2010 | 06:31 AM
JDM_SOHC's Avatar
Or a performance shop that deals with slightly modified cars on a day to day basis, they usually know someone right off the bat who will know how to handle your car's situation... And not charge you an arm and a leg like the stealership will..
Old Jun 22, 2010 | 07:22 AM
D Griff's Avatar
I don't know, I went to tire kingdom's performance store and they charged me like $120 because it was lowered. I think next time I'm going to go with firestone's lifetime alignment, they have gotten my car on their lift before without issues, they just wouldn't do it because they said I needed tie rods. My car was really low at the time, tucked a little in the rear and maybe pinkie finger gap up front.
Old Jun 22, 2010 | 07:23 AM
speedooo's Avatar
did you bother to take your bumper off?
next time find a place w/ a pit.
Old Jun 22, 2010 | 08:20 AM
Red_Army's Avatar
well if you don't already have tie rods they can't just be thrown in...so they're idiots. looks like your still lookin for a place to get it done.
120? you could just buy new tires for that much.
Old Jun 22, 2010 | 08:44 AM
peekeesh's Avatar
firestone did mine with no issues. front is tucked like -1 finger i think and rear has no gap at all. im in CA though if that matters.
Old Jun 22, 2010 | 08:47 AM
Reyracer19's Avatar
Excellent idea, I should have thought of that.
Deal is I got lifetime alignment at tiresplus and my passanger side tie rod is going bad so i'll replace it, remove the bumper and get the car aligned.
Think i should replace both sides while i'm at it? The car pulls a bit to the right and steering wheel shakes between 60-70 mph?
Old Jun 22, 2010 | 08:57 AM
jdm.coupe3234's Avatar
yeah i always take mine to a place down here called pueblo tires.. they have a bit. and the guy that does my alignment never gives me **** about my car being dumpt
Old Jun 22, 2010 | 09:01 AM
speedooo's Avatar
I always zip tie my bumper on when alginment day comes around each year lol and yes, replace both side while you're there. did they say inner or outter?
Old Jun 22, 2010 | 09:18 AM
90_EX_Civic's Avatar
i just followed this and it worked out fine. it's not 100% accurate,and you can only really do 0 toe.
https://honda-tech.com/forums/showth...ring+alignment
Old Jun 22, 2010 | 05:08 PM
Reyracer19's Avatar
Neither, they are morons. When I told them my problem they said it was the transmission the mount...??? The one on top that goes right againt the Right side beam...
So I ran and bought an OEM mount drove home to replace it....the mount is dirty yes (car has 130k 96') but the rubber is intact.
So my guess is either tie rod end going bad..inner/outer/both, ball joint, control arm(s) or bearing.
A buddy of mine suggested that it could be the axle as this mostly noted on acceleration.
jond
Suspension & Brakes
Aug 29, 2006 03:00 PM
Jer'rome
Aug 15, 2004 09:03 PM
careawholelot
Dec 17, 2002 11:44 AM
sackdz
Nov 21, 2001 01:05 PM
D
Jun 20, 2001 08:32 AM
