1 quick ?
Old Jun 21, 2010 | 07:32 PM
092eg6's Avatar
Default 1 quick ?
update on post #16
my car kinda boggs/choke right after u let go of the clutch on first gear while the car is already going. what can be cause of this?
oh and while idling with the AC on, it hesitates a little on idle.
any thoughts on what this can be cause by?
Old Jun 21, 2010 | 07:34 PM
OMG THE GOGGLES's Avatar
Default Re: 1 quick ?
What RPM does the car idle at? And also idle at with A/C on? That could be an issue. The AC is going to draw power and car will not ride the same as if it was off, so it could be 100% normal. Hard to tell without seeing it in person.
Old Jun 24, 2010 | 02:21 PM
092eg6's Avatar
wel heres a little video of it idling.
http://www.youtube.com/watch?v=ZeYN0fcZNo0
Old Jun 24, 2010 | 05:14 PM
From the video, it could be a few things, but I would take the AC belt off and see how freely the pulley on the compressor spins. It could easily be that the AC pulley is not working properly an when turned on it could be essentially dragging or pulling the belt by getting stuck on it. The car seemed to idle fine on its own though, at an avg rpm and everything. I am curious how freely the pulley spins (I would not test this while the car is running! lol)
Old Jun 25, 2010 | 06:19 PM
00Red_SiR's Avatar
All Motor Mentor
I find that's what happens when you run a torqueless motor like a b16a and a lightweight flywheel. What are you running?
Old Jun 25, 2010 | 06:44 PM
092eg6's Avatar
b20b bottomend, stock flywheel
Old Jun 26, 2010 | 07:03 AM
00Red_SiR's Avatar
All Motor Mentor
^^ I would do this and I would just quickly flash a timing light on the car to make sure it's where it's supposed to be for starters.
Old Jun 26, 2010 | 07:13 AM
gutted-dx's Avatar
Whats the whole motor setup? Timing, and the tune could be an issue. Does the compressor its self make any noise?
Old Jun 26, 2010 | 09:55 AM
092eg6's Avatar
b16 head/b20b block all stock internal, tuned on crome about 1 1/2 yr back, timming is 16 degree on idle, worked fine with the ac just until 2 weeks ago it started this.
Old Jun 26, 2010 | 10:55 AM
00Red_SiR's Avatar
All Motor Mentor
your fast idle valve may need to be cleaned. I'd remove it and spray it with some throttle body cleaner, maybe the port too which would require the removal of your throttle body to do more easily.
Old Jun 26, 2010 | 12:28 PM
092eg6's Avatar
sorry forgot to mention that its a obd2 TB that does not have the fast idle control valve
Old Jun 26, 2010 | 12:31 PM
092eg6's Avatar
im kinda getting to think that it may be because of my distributor because before this happen my rpm gauge was reading a bit lower than normal, it still is and its reading about 2-300 rpm lower than what it suppose to. but im just not sure
Old Jun 26, 2010 | 12:34 PM
092eg6's Avatar
i also thought it could of been the tps so i already check the tps sensor it's still reading at .5 close and 4.5 wot. so its still good.
Old Jun 26, 2010 | 03:17 PM
00Red_SiR's Avatar
All Motor Mentor
I meant to say IAC (Idle air control) I have an OBD2 TB and there is an air bypass mechanism to allow air to bypass the throttle when it's closed at Idle. This is what you need to clean and check.
Old Jun 27, 2010 | 08:20 AM
092eg6's Avatar
havent clean that iac out yet but i just check the timming with timming gun and is still at 16 degree on idle. next i will clean the iac out and see what happens
Old Jun 29, 2010 | 01:41 PM
092eg6's Avatar
I had a feeling that it might be something distributor related as i mention earlier in this thread, so I digged into the distributor and look what I found!!!!
The screw that holds the rotor in place came out and got stuck to the magnetic thing on the left side and the rotor was on its way out but somehow is still stuck but very loose. In the picture below i had already taken out the rotor but the ring is still on the rotor shaft.
i bolted everything back up nice and tight and now idles fine with the AC on. thanks for all your help guys, I appreciate it!
Old Jun 29, 2010 | 01:44 PM
Natural Aspirations's Avatar
LUCKY!
Props for finding the fix for your issue and posting your resolution
Old Jun 29, 2010 | 01:49 PM
092eg6's Avatar
trying to keep this "Honda-Tech" as possible!!
Andrew14
Jun 22, 2010 09:24 PM
JDM97R
Aug 7, 2004 11:59 AM
ek9mugen
23
Apr 10, 2004 10:32 PM
riceball777
Aug 18, 2003 10:11 AM
Mires
Jul 2, 2003 08:06 PM
