timing for B-series motor
Old Jun 21, 2010 | 09:57 AM
Civic483973's Avatar
Icon2 timing for B-series motor
how do you time a b20 block with gsr head and any diagrams would be appreciated
Old Jun 21, 2010 | 10:39 AM
apexi_rsx's Avatar
Default Re: timing for B-series motor
cant u set the block to TDC on cylinder one? the b series have lil holes in the cam where u can slide a drill bit thru to hold the cams in place through alil fish eye on both intake and exhaust. look at it its pretty simple to time a b series. crank should have a timing mark on the oil pump housing.
Old Jun 21, 2010 | 11:37 AM
so cranshaft TDC and make sure the cams line up with the wholes on the head?
do i need to spend crankshaft twice to make sure everything is in time?
Old Jun 21, 2010 | 11:58 AM
92bseries's Avatar
tdc for the block is cyl 1 and 3 at top position, then put the head on and your cam gears should have two little slits on them making sure they are facing each other bolt the cam cap rails down put the timing belt on and rotate the assembly a few times and if the 2 marks align each time they spin around, your motor should be good to go
Old Jun 21, 2010 | 06:42 PM
thanks very much
and do you have to put the belt on clockwise or counterclockwise?
Old Jun 22, 2010 | 11:51 AM
i have a b20 and the 1 and 4 piston come up together not the 1 and 3
Old Jun 22, 2010 | 12:05 PM
averyvm's Avatar
You should put the belt on starting from the Crank pulley. After that you do the water pump and tensioner. After that you do EXHAUST side next to remove all slack between pulley and exhaust cam and then you intake last. Hope that helps.
Old Jun 22, 2010 | 07:32 PM
it does
thanks a lot
Old Jun 30, 2010 | 05:18 AM
ibiris's Avatar
Just a quick question in relation to the timing marker;
When checking the timing, my manual says to point the timing light from directly above onto the marker and mark on the pulley.
However, the long marker is at an angle to the engine (i.e. not perfectly vertical). Do I need to point the timing light down the marker at the same angle so they are parallel as such, or do I still point it directly down on top of it.
I'm worried the difference between the two would affect how the timing is set when I do it.
heff11
Jul 1, 2015 05:55 PM
93egboosted
Mar 2, 2011 05:37 AM
B20b4me
Aug 11, 2008 10:43 AM
Sikocivic
Apr 26, 2006 12:45 PM
gATOr65
Dec 27, 2005 02:03 PM
