b20vtec question, which cam?
Old Jun 20, 2010 | 11:32 PM
tooquik209's Avatar
Default b20vtec question, which cam?
wanted to know what cam would be good for midrange power since im going to be running a stock b20vtec, only plan on taking it to 7500 rpms. just needed your guys opinion whom have alot of experience with b20v builds. also using the stock itr valvetrain
specs:
-2000 itr head, (ditching the itr cams maybe)
-stock b20b block
-hondata s200
-bisimoto headers
-itr tranny
thanks
Old Jun 20, 2010 | 11:35 PM
mouab18c1's Avatar
Default Re: b20vtec question, which cam?
Keep the ITR cams!
Old Jun 20, 2010 | 11:38 PM
tooquik209's Avatar
Originally Posted by mouab18c1
Keep the ITR cams!
bec my friend made 187whp and 134 torque if im correct with the same setup with itr headers, and no hondata, would my setup be closer to 200? just curious
Old Jun 21, 2010 | 03:30 AM
negusjuda's Avatar
maybe the 190 range 200 is a lil hard to reach with itr cams but being that you have the stock b20 pistons you can run anything bigger then itr cams without having piston to valve issues but who knows anything is possible
Old Jun 21, 2010 | 04:18 AM
fsg231's Avatar
dont stock ITR cams power out around 180..?? i would say a set of street blox cams, or skunk tuner 1's will break the 200whp mark... either way, invest in some 310injectors, IM, and TB...that will help alot
Old Jun 21, 2010 | 04:22 AM
negusjuda's Avatar
he wont be able to run those cams because of the valve reliefs of the b20 pistons i mean he can risk it but he has atleast a 80 percent chance of the pistons hitting the valves
Old Jun 21, 2010 | 09:41 AM
tooquik209's Avatar
it has a blox manifold with itr throttle bodie on it, i was planning on running a set of rc injectors dont know what size yet, so blox or skunk2 cams will have valve and piston issues? bec ive been told otherwise
Old Jun 21, 2010 | 09:46 AM
negusjuda's Avatar
yes i wouldnt run anything bigger then itr cams unless you cut the valve reliefs on the pistons or get some rs machine pistons
Old Jun 21, 2010 | 10:50 AM
tooquik209's Avatar
i would get pistons but its to much of a hassle right now, im just looking for a high 13's car right now, my friends setup in a ej1 ran 14.2, which is what im doing. would the bisimoto headers with the stock itr head put me there? as well with the injectors and hondata, and good tune?
Old Jun 21, 2010 | 08:49 PM
mouab18c1's Avatar
I think you should be in the high 13's without a doubt.
Old Jun 22, 2010 | 11:19 AM
tooquik209's Avatar
i know the rod bolts are weak but has anyone done a similar setup to mines going to 7500? also installing a pcv and breather kit, would this also benefit me?
Old Jun 22, 2010 | 02:13 PM
mouab18c1's Avatar
I took my stock b20vtec with gsr head to 7800rpm everytime I floored it.
Old Jun 22, 2010 | 03:09 PM
tooquik209's Avatar
how long did it last you? did u get it dynoed?
Old Jul 11, 2010 | 02:18 AM
acydphryck's Avatar
blox b cams
Old Jul 11, 2010 | 09:12 AM
gutted-dx's Avatar
Is that a stock bottom end?
Old Jul 11, 2010 | 04:01 PM
acydphryck's Avatar
RS ITR cast pistons, stock sleeves on stock B20B block and crank...stock b20 rods to boot ;-P
Old Jul 11, 2010 | 05:39 PM
gutted-dx's Avatar
That dyno has nothing to do with this thread, hes staying with stock pistons.
Old Jul 11, 2010 | 07:45 PM
KevinBrown's Avatar
You may want to get some port work if you're pushing for 200whp. It will be hard, but who knows...you may get lucky. And I wouldn't run anything bigger than ITR cams. That's just asking for trouble. You probably don't know if or how much your head has been milled?
Also, your rod bolts are going to be perfectly fine to 7500. I had a friend who pushed his to 8200-8500. And it didn't even make power that high.
Old Jul 11, 2010 | 08:27 PM
all-mtr-teg's Avatar
Stock LS rod bolts will handle 9k rpm. I've personally done it on one of my builds which had over 75k miles before I opened it up to replace the rings.
Old Jul 11, 2010 | 08:50 PM
gpdub's Avatar
buddy club spec III's would move out. i got a set if interested, letting go cheap since i upgraded to spec IV's so i can rev it real high but for 7700rpm, spec IIIs would be just right
Old Jul 12, 2010 | 03:11 AM
negusjuda's Avatar
i wouldnt run these cams with stock pistons thats asking for trouble
egjdmcivichatch
Mar 30, 2011 01:54 AM
turbodailydan
Jan 21, 2010 06:12 PM
akasen8
Jun 28, 2004 07:52 PM
Charlie Moua
Mar 17, 2003 06:54 AM
bboychris
Aug 4, 2002 06:13 PM
