fuel injection problems, prolly an easy fix lol
Old Jun 20, 2010 | 06:37 PM
88HATCH(:'s Avatar
Default fuel injection problems, prolly an easy fix lol
just bought a 88 hatch, only problem it has is that the motor isnt getting fuel, i checked the lines and i have pressure all the way to the injection system. and no its not a ignioton issue, i have spark, you can start the car by pouing fuel into the intake, so please any help on wht i might need to look at.
Old Jun 20, 2010 | 06:50 PM
D16SiHatch's Avatar
Default Re: fuel injection problems, prolly an easy fix lol
main fuel relay. they are a common failing point that leads to no start situations.
some people take them apart and resolder the internal connections, otherwise i would just replace it. it's located above the driverside kickpanel area.
Old Jun 20, 2010 | 07:31 PM
88HATCH(:'s Avatar
thanks alot i appreciate it, ill try it lol
Old Jun 20, 2010 | 07:35 PM
D16SiHatch's Avatar
actually now that i think about it. you said you had pressure at the lines. if the fuel relay was bad your fuel pump wouldn't kick on and you would not have fuel pressure at the lines. something is preventing the injectors from firing. one side of the injector goes to always on power, and the other runs back to the ecu. when the ecu provides a ground pulse, this is what triggers the injector to squirt fuel into the engine.
Old Jun 20, 2010 | 07:40 PM
88HATCH(:'s Avatar
any ideas on where i should look first ?
schramaj
Jan 3, 2013 03:37 PM
Jruiz3505
Dec 6, 2011 02:40 PM
B18 CYA
Aug 17, 2006 03:29 PM
B18 CYA
Jul 5, 2006 07:46 PM
StraightCivic
Apr 24, 2006 03:58 AM
