Rust in Gas Tank..
Old Jun 20, 2010 | 06:32 PM
tgibson's Avatar
Default Rust in Gas Tank..
Quick question, I have a 1995 Eg that has rust in the gas tank.. I've been having to keep at least 1/8 or 1/4 full otherwise, I loose all power. I know there is rust in the tank, because I took the filter off and let gas run through the lines and seen the gas was dark orange.
My question is, does anyone know how to remove rust from your tank, without having to drop it, and power-wash it or without having to buy a new tank?
Old Jun 20, 2010 | 07:58 PM
LuczOr's Avatar
Default Re: Rust in Gas Tank..
Get a new tank... and PUT MORE GAS IN IT. The reason a tank rusts is because people hi-$5 their tanks at the pump. The more you fill it, the more the tank will be coated with wonderful gasoline, preventing rust.
Old Jun 20, 2010 | 08:11 PM
Linked's Avatar
damnit ...
Old Jun 20, 2010 | 08:14 PM
D16SiHatch's Avatar
agreed with luczOr. if it's already rusted out like that then your only option to fix it is replacing the tank.
Old Jun 21, 2010 | 04:49 PM
quapouh's Avatar
once the rusting started it's just a question of time (even if you flush it) until it returns again - FIND A PARTS CAR that wasn't standing for 2 long (soon after the wreck or engine failure)
Old Jan 1, 2011 | 05:54 PM
fleabag's Avatar
If he's really dedicated, he could just drain and remove the tank entirely... dry out the tank so it's clean, then, assuming the tank truly is free of any gasoline vapors, soak the tank in CLR for a few hours. Rinse the tank with fresh water, wipe down and dry the tank immediately so no rust forms, try to inspect the tank to see if there is still rust and then if it looks good, you can put it back. Rust forms because there is WATER inside of the tank.. not a good thing to have inside of your gas tank!
Old Jan 1, 2011 | 07:00 PM
Dontoh's Avatar
agreed^
Old Jan 1, 2011 | 07:09 PM
95ProjectEJ1's Avatar
A pressure washer (wash) and a compressor with a hose attachment (dry) will help also. That is of course, you have access to both.
ezol
Mar 19, 2008 03:39 PM
seven12
Jul 10, 2006 08:24 PM
null.
Jun 22, 2005 07:03 PM
STN_Pat
Oct 2, 2004 07:02 PM
1hotintegra
Aug 28, 2002 11:30 AM
