Honda S2000 Honda S2000
Bad Vibration In Rear
Old Jun 20, 2010 | 03:32 PM
H8BOOST's Avatar
Default Bad Vibration In Rear
I noticed this vibration after the installation of my coilovers. When accelerating the vibration gets worse. But when at cruising speeds there is very minor vibration. The vibration is coming from the rear as far as i can tell.
I replaced the the diff about a year ago and the right axle. I read somewhere that someone replaced there axle with a re manufactured axle and it caused bad vibration. Could this be the problem.
Old Jun 20, 2010 | 04:11 PM
bigmacnfries's Avatar
Default Re: Bad Vibration In Rear
whenever i get vibration in the rear, it's usually just wind.
Old Jun 20, 2010 | 04:30 PM
S2K-APWON's Avatar
After lowering your S the axles slightly get stretched and will cause the vibrations. There 2 ways to fix this problem.
1. Is by buying shaft spacers
^The red pieces
2. Free. By switching your inner cv joints-A how to-http://www.s2ki.com/forums/index.php?showtopic=241367
I myself went with the spacers. Installed them by myself and took me about an hour. The more you drive with the rear shaking the worse your axle's will get.
Switching your inner cv's will take more time and you got to know exactly what you are doing.
Good luck
Old Jun 20, 2010 | 05:00 PM
Did you get your alignment etc. done after the install?
Old Jun 20, 2010 | 06:06 PM
bky's Avatar
bky
Classic vibration from lowering. Halfshaft spacer fixes it for $100
Old Jun 20, 2010 | 06:41 PM
H8BOOST's Avatar
Yes i got and alignment about 3 months ago. I will try the spacers. I hope that fixes the problem. Is there a specific size that i need to get??
Old Jun 20, 2010 | 09:16 PM
S2K-APWON's Avatar
Alignment will not fix this kind of problem.
All or most spacers come in 10mm size.
I am almost 100% positive this will fix or help the problem.
Old Jun 21, 2010 | 12:16 PM
CHONCH2's Avatar
i concur. i had the same issue with mine. but my rear was too low, so i raised it back up and the vibration went away.
but i've had experience with other s2k's and the spacers always fix it.
Old Jun 21, 2010 | 04:15 PM
H8BOOST's Avatar
Thank you, I will do the spacers. I could only find T1R spacers and another brand. I also found megan racing spacers for 99$. I dunno about those, any thoughts on them. Or just go with the T1R I found them for 150.
Old Jun 21, 2010 | 09:37 PM
S2K-APWON's Avatar
I have T1R spacers. Usually doesn't matter on what spacer you go with, its just a 10mm wide piece of metal. Hell, you can machine your own if you are good with metal.
But for a easier install i recommend getting 2 piece spacers. One piece spacers arent that hard to install anyway.
Old Jun 22, 2010 | 02:00 PM
H8BOOST's Avatar
Thanks Bro. Ordered them Today. Hope To Have Them By The End Of The Week. My Car Feels Like Its Coming Apart. I hope This Works.
jimmy o.
Dec 31, 2009 04:51 PM
desi01
Dec 18, 2009 04:40 AM
kennyb3030
Oct 27, 2008 11:46 AM
Kronn 98SH
May 1, 2005 05:24 PM
216.226.142.95:27016
Apr 8, 2003 12:47 PM
