d15b2 with Z6 head mini me issues
Old Jun 20, 2010 | 02:15 PM
nani's Avatar
Default d15b2 with Z6 head mini me issues
well the swap is complete but im experiencing some issues with the engine, it started fine yesterday but it was flooding the headers with gas... seems that the injectors are staying open all the time, lots of smoke coming from the exhaust.
it has a P28 ecu, D16z6 head, d16z6 distributor, and a OBD0 to OBD1 jumper. I did all the DPFI to MPFI wiring with the many write ups that are on this board.
By the way it used to be an auto I converted to manual. thanks in advance for any input.
Old Jun 21, 2010 | 04:26 PM
nani's Avatar
Default Re: d15b2 with Z6 head mini me issues
help a brother out please... I searched but couldn't find any relevant information
Old Jul 14, 2010 | 06:47 PM
nani's Avatar
bump!!!
Old Jul 14, 2010 | 07:37 PM
TheAsian's Avatar
Have you driven it. About how fast are you going through gas. Any codes?
Old Jul 16, 2010 | 11:21 AM
nani's Avatar
this thing is spitting lots of gas... its like the injector never closes. Im gonna try another ECU
Old Jul 16, 2010 | 12:09 PM
91CrxMann's Avatar
id check throttle linkage, and make sure tb butterfly opens and closes..
id take the gay obd0-1 one **** out of there... use ur stock intake assembly and dizzy.. wire vtec to rpm or vtec contoller(or one wire ecu for obd0).... sounds like injectors are ****ed... maybe u need to replace the o ring seal or tighten down the fuel rail
Old Jul 16, 2010 | 12:12 PM
91CrxMann's Avatar
correct me if i am wrong but i believe the injectors from the d15 are not the same as the ones on the d16, something to do with the regulator....could be ur using two different parts of the fuel injection system... so the ecu thinks the injectors are opening and closing but they arent.. they are open and fuels flowing in, instead of pulsating
Old Jul 16, 2010 | 03:32 PM
nani's Avatar
I got two brand new injectors and did the same thing.... throttle body opens and closes fine. this thing is driving me nuts!!
Old Jul 16, 2010 | 03:34 PM
nani's Avatar
we have high impedance injectors there... so theres no resistor box. all injectors have 12v and 14ohm resistance.
Old Jul 17, 2010 | 10:17 AM
91CrxMann's Avatar
where did the ecu come from? possibly got some problems... best of luck
Adam Smith
Oct 21, 2022 07:16 PM
ww3slayer
Aug 23, 2010 04:28 PM
stevew84
May 19, 2008 04:34 PM
nunshavenofun
11
Sep 23, 2005 02:47 PM
bhummel
14
Nov 13, 2003 10:48 AM
