Suspension & Brakes Theory, alignment, spring rates....
Sway/Tie/ C pillar bar for the rear question
Old Jun 20, 2010 | 12:24 PM
redlinexd's Avatar
Icon2 Sway/Tie/ C pillar bar for the rear question
I installed a Rear lower tie bar, a rear upper tie bar on my EG, and i was planning to buy & install a C pillar bar. If i intend to add a C pillar bar for the rear, will it give any extra difference on stiffening the rear?
Old Jun 20, 2010 | 12:47 PM
alphalanos's Avatar
Default Re: Sway/Tie/ C pillar bar for the rear question
wait.
lower tie bar - ok
upper tie bar? you mean shock tower bar? - ok
C-pillar bar - nearly useless
SWAY bar - one of the best things you can do to your car. depending on the car an ASR brace and a CTR 22mm swaybar usually does perfectly.
forgot to mention if you do end up with ASR brace it renders a separate lower tie bar useless because it functions as a tie bar as well.
Old Jun 20, 2010 | 01:49 PM
Drive 4 fun's Avatar
C pillar bar without triangulation may not do anything, and even with triagulation may not add significant stiffness. Perhaps bling, or clothes rack. I tried in Integra and cannot notice much/any.
Cody08
May 1, 2018 09:28 AM
Try2Live4God
Feb 23, 2005 06:30 AM
^Sammy]!.
Feb 7, 2004 08:15 AM
T_Rex
36
Jan 23, 2003 05:45 PM
