Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Need Help with Rear
Old Jun 19, 2010 | 09:45 PM
So krazieY's Avatar
Default Need Help with Rear
In about a week i going to put my sportline on, but i was looking at the DIY, the rear part look difficult. I use to own a EP3 and when we did suspension work it was the old fashion spring on strut. Do you guy have any pointer for the rear.
Thanks
Old Jun 20, 2010 | 07:56 AM
T3KNiQe's Avatar
Default Re: Need Help with Rear
Uhhh springs only right? I don't think they're any diy on ht, I know thiers a couple on 8th. I honestly can't really remember what I unbolted, I think I just unbolted the toe adjustment bar from the knuckle if you will. Then I just pryed out the stock springs and replaced with s tech from tein. I didn't cut the bump stops, it was only a 1.5" drop in the rear so I thought it wasn't needed. Haven't had problems. Some people will say pull back the trunk carpet liner to access the spring from the top, that's extra work IMO I think you do that if you wanna cut the bump stops. Idk I just did mine in a rush.
Old Jun 20, 2010 | 09:58 AM
DFW's Avatar
DFW
unbolt the lower shock mounting bolt, the upper camber arm bolt, and sway bar endlink. might want to unbolt/move the brake hardline out of the way, but ive never have. you will probably need another person to push down on the rotor and another person pull the spring out.
Old Jun 20, 2010 | 10:36 AM
T3KNiQe's Avatar
^ yeah ok, all I did was take out the lower shock bolt.
Old Jun 20, 2010 | 11:28 AM
2008fijibluesi's Avatar
There's no access to the springs through the trunk. That's funny.
Old Jun 20, 2010 | 05:43 PM
T3KNiQe's Avatar
Well it's actually to access the shock, my bad. It's there, Honda just did a really good job of hiding it with carpet.
Old Jun 20, 2010 | 09:23 PM
No I know you can access the strut, but you said spring.
a2dadamm
14
Jul 9, 2007 09:43 AM
95teggie
Suspension & Brakes
Apr 15, 2006 10:05 AM
Lo-Buck EF
Jan 19, 2004 06:45 PM
Steve91
12
Mar 11, 2003 05:58 PM
FritzInTN
Jul 30, 2002 09:22 AM
